Old 07-19-2004, 11:05 PM   #11596
Still Bill's Avatar
Originally posted by losispeed
Hey Lazy, whats the point of running AE hex hubs on the Losi?
They are wider than standard and give you a wider track. Takes the width of the XXX-S from about 185mm to just shy of 190mm.
Have to use the low profile wheel nuts with them to make sure that you get some plastic locking material on the threads of the stub axle. Or using the slightly longer AE stub axles is an alternative option.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 07-19-2004, 11:06 PM   #11597
Cardboard's Avatar
Send a message via AIM to Cardboard
I'm not lazyboy, but most of the time people use it to make the car wider.
Cardboard is offline   Reply With Quote
Old 07-19-2004, 11:09 PM   #11598
Still Bill's Avatar
Default Niftech for my XXX-S
Can anyone provide any input about Niftech diffs and dogbones?
Seems kind of expensive; but, their potential looks good.
Thanks.
Old 07-20-2004, 01:43 AM   #11599
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Aluminum outdrives seem to get a lot of slop in them pretty quickly. I do know that Niftech stuff in general is ultra high quality though, and I am sure that those products are as well, so you'll propably have very little slop to start out with to prolong their life.
Old 07-20-2004, 10:28 AM   #11600
Thanks for the info Bill. I figure if I screw up badly I'll just get me some new ones. right? The move happens in one week. I'm a far way from getting everything ready. Guess I'm a last minuter eh? But the local track will be in town. And with my new Schedule being off every other saturday, (Sweet!) I should be able to make this car a carpet killer. Even have the Dremel for the chassis if I'm so inclined.
As much as I modified my YZ, don't be surprised to see this car be a shell of it's former self too. I just need to get to that track and practice, adjust, practice, adjust, and practice more.
wcoyote is offline   Reply With Quote
Old 07-20-2004, 02:33 PM   #11601
Formula1fan's Avatar
Hello, I was wondering if the aluminum steering makes a big difference. I think someone said it removes slop. I looked at speedtech’s and the Matt Francis version and also wondered if one was better than the other. Thanks
Formula1fan is offline   Reply With Quote
Old 07-20-2004, 02:48 PM   #11602
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
I personally have tried both and still like the plastic ones better.
JohnMatrix is offline   Reply With Quote
Old 07-20-2004, 02:52 PM   #11603
Interesting, Thanks
Does Losi have a spring set or do you have to buy them seperate. If they do does anyone know the part#
Old 07-20-2004, 02:55 PM   #11604
The alum. steering rack is a waste of money I think. It doesn't really remove any slop. The speedtech and MF versions are pretty much the same spec except one is anodized and the other isn't. Losi does not sell a spring kit, you need to purchase them all separate. There is a list on their website. http://www.teamlosi.com/techtips/spring_chart.htm
James Nguyen is offline   Reply With Quote
Old 07-20-2004, 03:01 PM   #11605
Good lookin' out! More money for motors
Old 07-20-2004, 03:23 PM   #11606
I agree on the aluminum steering, dont get the bell cranks but the drag link might be worth the money. I say this because I've modified my steering to have a ball stud in the center of the draglink so I can use a turnbuckle to center my assembly instead of popping the ball stud to adjust. But the bell cranks suck, if you hit something even moderately hard they will bend. You can bend them back but that just fatigues the metal so the wind from a passing bug will bend them again. The plastic ones will give before they break altogether and once they do break they're a lot less expensive to replace.
Poppa Ray is offline   Reply With Quote
Old 07-20-2004, 04:41 PM   #11607
mwcet8k's Avatar
You also don't have to worry about the screws that connect the bell cranks and drag link unscrewing themselves if you use the plastic bell cranks.
mwcet8k is offline   Reply With Quote
Old 07-20-2004, 04:45 PM   #11608
HarshGuy's Avatar
LOL ...that happened to me last week at the nats ...that and I tore the link that goes between the 2 bellcranks in half ...no idea how!!
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 07-20-2004, 05:56 PM   #11609
mwcet8k's Avatar
You tore apart the drag link?!!! Impressive!!
Old 07-20-2004, 07:15 PM   #11610
STLNLST's Avatar
Trader Rating: 21 (100%+)
Rookie...
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
