Old 07-12-2004, 10:19 PM   #11536
Still Bill's Avatar
Originally posted by JayBee
But my question is, what is the part number for the front bumper on G+; I wanna put one on my Losi RTR
-JayBee
JayBee,
Just go to the teamlosi.com site and look at the assembly diagrams of the cars for their respective part numbers; then, add "LOSA-" (new way) or "A-" (old way) in front of that 4-digit number and contact your lhs.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 07-13-2004, 02:10 AM   #11537
HarshGuy's Avatar
Originally posted by XXX-S Bill
He means no calories...
He meant no carbs
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 07-13-2004, 12:23 PM   #11538
Default CHASSIS
just wondering what chassis you use on ur XXX-s G+ whether you use the standard G+ chassis with all the milling on it or if you use the graphite chassis without all the holes.
Bony85 is offline   Reply With Quote
Old 07-13-2004, 12:49 PM   #11539
mwcet8k's Avatar
Actually, the standard G+ chassis is the graphite one with holes milled out along the bottom. The chassis that isn't milled is not graphite, it's just the standard Losi plastic. But to answer your question, most of us run the graphite chassis.
mwcet8k is offline   Reply With Quote
Old 07-13-2004, 04:06 PM   #11540
mwcet8k's Avatar
Default Random XXX-S Tip
Just came up with this one and thought I'd share it w/ all of you.
One part of the xxxs design that I've never liked is the way the ESC wire is retained where it runs around the motor. I've always had a problem with the retainer screws rubbing against the wires when I thread them in, which can cut into the insulation and cause all sorts of other problems (including interference). I'm guessing some of you have had this problem too. The fix I came up with is to screw the longer Losi droop screws up through the bottom of those retainer holes in the chassis so that the bottom of the screw is flush with the bottom of the chassis (do this without the ESC wires in place). After you've done this, slide the ESC wires into the retainer groove and use your fingers to thread a 4-40 zinc nut (part # A-6300) onto the droop screws to hold the wires in place. Since the screw never rubs against the wires when you're threading it in you don't have to worry about damaging them.
Old 07-13-2004, 04:08 PM   #11541
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I've also just shoe-gooed it in the channel in the past.
Jon Kerr is offline   Reply With Quote
Old 07-13-2004, 04:09 PM   #11542
BadBoyRC's Avatar
Trader Rating: 2 (75%+)
Harshness no I didn't mean no carbs... carbs are for gas cars (see nitro thread)
your such a naughty boy I have Sue Lee wants to show you ..click on attachment.
BadBoyRC is offline   Reply With Quote
Old 07-14-2004, 10:04 AM   #11543
Hopefully these pics will go though of my car
wcoyote is offline   Reply With Quote
Old 07-14-2004, 10:05 AM   #11544
Darn they didn't attach.
Old 07-14-2004, 10:11 AM   #11545
one more try
Old 07-14-2004, 10:17 AM   #11546
the body...
Old 07-14-2004, 10:22 AM   #11547
And the finished product. By the way that is candy blue with my own black backing, making it a dark purple blue candy. It's more purple but up close you can see the blue to it. My only second paint job.
Old 07-14-2004, 10:25 AM   #11548
BadBoyRC's Avatar
cool ride dude.. good luck racing.. and suporting the team losi.
Old 07-14-2004, 10:28 AM   #11549
try again.
Old 07-14-2004, 11:01 AM   #11550
In the first pic, you'll see that the battery holddown is not completely down. The 7 cells were in a hump pack config from my JRX-Pro SE. I was able to fix that after running a few times, so it lays flat now. But I had to take it out for a trial run with the battery as it was shown. I couldn't wait long enough to fix it..and yes that is a Mr series 16T motor. I know old, but it still screams. It was the perfect motor to test the car's, and my, capabilities. Faster than stock but still controllable. Especially since I race mod almost exclusively. I have an old Mr Series 12T for when I get used to the car and need more speed. I also have another battery pack in the works.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
