Old 07-09-2004, 08:27 AM   #11491
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Actually Associated also has the aluminum versions. The problem I had with the graphite ones is by the time I had cranked down the locknut to get some nylon on the axle threads, the hex had bent the axle pin and pushed itself right against the axle bearing. I only use the AE hexes for carpet, Dynamite for everywhere else...
Old 07-09-2004, 09:04 AM   #11492
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
i put tc3 axles on the car and this allows the nylon part of the lock nut to have threads to lock on to... havent tried it with the stock spacers yet tho, it should be ok on those as well...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 07-09-2004, 03:51 PM   #11493
rctoyguy's Avatar
Trader Rating: 21 (100%+)
Default Receiver / ESC Placement
This has probably been covered in this thread, but I can't figure out how to search within a thread, and I can't read through 384 pages of posts without pulling my hair out...
Most of the pictures I see of XXX-Ss have the Rx just behind the steering servo and the ESC behind the motor - but, I read somewhere (don't recall where) that putting the ESC in front of the motor was better for balance.
What do you think is the best placement?
Jeff
rctoyguy is offline   Reply With Quote
Old 07-09-2004, 04:02 PM   #11494
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I've seen guys running both and they always seem to end up with the ESC back behind motor. I'm sure it give better ballance but I've seen some guys have glitching problems with that layout and I've also seen guys that just didn't like the way it felt.
Jon Kerr is offline   Reply With Quote
Old 07-09-2004, 04:12 PM   #11495
TLRacing
Todd Hodge's Avatar
Default Re: ONE WAY
Originally posted by woozer71
Hi guys
I put a one way in my losi about 2 months ago. I have ran it about 6 times. The last time I ran the car the left hub internal bearing was totally destroyed. I was wondering if someone else has had the same problem and if so how did they fix it? And what would cause it?
Also another note on the oneways. Take your Xacto knife and gently score the outer diameter where the support bearing sits. Then press in the bearing. It should now fit nice and snug. Then score the oneway outdrive where the inner diameter of the support bearing will ride. Now press in the outdrive into the oneway hub. It should be a snug fit. This allows you to not run the oneway springs and keeps the outdrives from pulling out during a run. I think what happens is that when your running your oneway and you hit a bump, curb, road dome, it compresses upward and breaks out the plastic cage of the oneway bearing. I have done this to all my oneway's and have not had any problems.
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 07-09-2004, 04:15 PM   #11496
TLRacing
Todd Hodge's Avatar
Default Re: Receiver / ESC Placement
By moving the ESC in front of the motor the car it gives you more of a 50/50 front to rear weight balance. By running the ESC behing the motor you do not have a equal amount of weight on the opposite side. I also felt that my car drove more balanced.
Todd Hodge
Old 07-09-2004, 04:19 PM   #11497
rctoyguy's Avatar
T. Hodge - you felt your car drove more balanced which way? I can't tell which way you mean - Can I assume you mean with it in front of the motor?
Sounds like this is a user preference kind of thing...
*edit* - when all else fails, read the book
The book shows the ESC behind the motor. I currently have the Rx on top of the servo, with the ESC between it and the motor - I plan on adding a personal transponder in the next week or so, and I don't know where to mount it with this setup - looks like most folks mount the transponder on top of the servo.
Jeff
Old 07-09-2004, 04:25 PM   #11498
TLRacing
Todd Hodge's Avatar
rctoyguy-I felt the car was balanced more front to rear. My car felt to have less steering but the laptimes were the same. I agree that this is a personal preference.
Todd Hodge
Old 07-09-2004, 04:29 PM   #11499
rctoyguy's Avatar
Sorry to beat it to death - but I still don't know if you mean the car drove more balanced with the ESC in front of or behind the motor --- that is what I meant.
Based on my most recent edit of the post above, I guess I will move the ESC and RX to make room for the transponder - unless someone gives me a good enough reason to do differently.
Jeff
Old 07-09-2004, 04:35 PM   #11500
Jon Kerr's Avatar
He means it felt better with the ESC in front. You can probably fit the transponder on the tunnel between it and the ESC.
Old 07-09-2004, 04:56 PM   #11501
racer-oZ's Avatar
R/C Tech Charter Subscriber
I liked my car with the receiver and speedo in front of the motor, but I could not get ride of a radio glitch. I can't say that caused it, but once I moved the speedo to the back of the car and put the receiver up on end I've been glitch free ever since. Just an fyi in case you try the new layout and have glitch problems.
racer-oZ
ps... Todd I may come up and introduce myself at the mod nats in Portland, I'll likely be looking for some setup tips once you get her all dialed in. I'm racing mod and 19turn, don't worry I'll get out of your way in mod.
racer-oZ is offline   Reply With Quote
Old 07-09-2004, 05:01 PM   #11502
Jeff Werner's Avatar
Send a message via Yahoo to Jeff Werner
Cool info on the oneway. I know here locally that the spool has taken over because of the impression that the oneways were fragile....bet that tip would help a bunch.
Racer- kinko trip go well????
Jeff
Jeff Werner is offline   Reply With Quote
Old 07-09-2004, 05:02 PM   #11503
racer-oZ's Avatar
Jeff, yes I did good at Kinkos. lol.... hey by the way you need to check the Topeka thread and tell John what engine you bought for your nitro.
racer-oZ
Old 07-09-2004, 08:32 PM   #11504
Pivot blocks revisisted.....
What will using the rear pivot supports on the front end of the car do for me ?
SteveG is offline   Reply With Quote
Old 07-09-2004, 08:38 PM   #11505
Oneway diff....
What will using a oneway diff with the above pivot block swap be like ?
I'd like to keep the amount of steering going in that I have now (or even gain a little) but would definately like a little more on power steering...
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
