Old 07-08-2004, 06:12 AM   #11476
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally posted by Randy Caster
JayBee - What rims are you using?
Yokomo dish (hard ones)
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-08-2004, 06:24 AM   #11477
racer-oZ's Avatar
R/C Tech Charter Subscriber
Default one-way
woozer71, welcome to the one-way club. I know some guys will debate me on this one, but personally I think the Losi one-ways are fragile and once it is blown you can't fix it. You can buy a left or right side to replace whichever side you broke, but they are $27 bucks a side and you can get the whole one-way with outdrives for $60.
I've been running the spool instead of the one-way, but I keep a one-way in my box just for those occassions where I believe the one-way is faster.
racer-oZ
racer-oZ is offline   Reply With Quote
Old 07-08-2004, 07:09 AM   #11478
rocketron's Avatar
Trader Rating: 16 (100%+)
Default Re: ONE WAY
Originally posted by woozer71
Hi guys
I put a one way in my losi about 2 months ago. I have ran it about 6 times. The last time I ran the car the left hub internal bearing was totally destroyed. I was wondering if someone else has had the same problem and if so how did they fix it? And what would cause it?
i've had this same problem before. broke two in a matter of weeks. all i've done to prevent this is to use a light high quality oil, and put a drop or two in the one-way bearing every 4 or so race weekends. oil shouldn't be thick and there is one way oil sold but i haven't tried that. been using the same one way for the past several months now.
rocketron is offline   Reply With Quote
Old 07-08-2004, 07:35 AM   #11479
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I haven't broken a oneway in the sedan but I broke three in the buggy. I stopped running them in the buggy for that reason.
Jon Kerr is offline   Reply With Quote
Old 07-08-2004, 07:46 AM   #11480
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
get the tech racing oneway, indestructable......
Matt M. is offline   Reply With Quote
Old 07-08-2004, 09:09 AM   #11481
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I know Yokomo used to make a few different offset wheels, this may be your problem. I use the Yokomo precision dish wheels and never have the problem your describing.
Old 07-08-2004, 09:31 AM   #11482
cartmen34's Avatar
I assume you are talking about this oneway?
http://www.tech-racing.co.jp/op_parts_f_oneway.htm
Has anyone ever tried it in a XXX-4?
Are there any US distributors for tech stuff?
cartmen34 is offline   Reply With Quote
Old 07-08-2004, 04:48 PM   #11483
Does anyone have a good setup for either a 19t or 27t on a really tight track. The track size is roughly 60' x 30'.
PSI Racer is offline   Reply With Quote
Old 07-08-2004, 04:56 PM   #11484
When using the Tamyia shocks with the new PRP towers do will you have to adjust the droop the same way?
And does anyone know how to order one of those Tech one ways?
Titan Racing is offline   Reply With Quote
Old 07-08-2004, 05:27 PM   #11485
Rockheadsguy's Avatar
Send a message via AIM to Rockheadsguy
I tried ordering the Tech Racing one-way from rcmodel.com.hk a couple weeks back but they wrote and said it was "out of production". I hate breaking the regular Losi bearings, but I guess I'm going to have to go back to them...
Rockheadsguy is offline   Reply With Quote
Old 07-08-2004, 06:20 PM   #11486
Yeah I had the same problem. Was hoping it was just me but guess not.
I have a question about Trinity Red Hop Ups. Do they make the battery strap and posts? If so anyone know the part number and where can I find them?
Old 07-08-2004, 08:41 PM   #11487
This may have been covered and if so, I apologize.
Why do people run TC3 hex adapters on their Losi's? I've read it is to increase track width, but have also been told it is to free up the car a bit. However I was under the impression that increasing track width would increase traction. Am I dead wrong or what? If someone could educate me it would be appreciated.
Also, are the Clamping style Trinity MF hubs the same width as the stockers as I would expect or are they wider also?
Thanks,
Griffin
Griffin is offline   Reply With Quote
Old 07-08-2004, 10:26 PM   #11488
Jaybo's Avatar
im after some tc3 hexes as i want some aluminium ones and cant find anywhere that stocks them specifically for the losi
Jaybo is offline   Reply With Quote
Old 07-08-2004, 11:09 PM   #11489
EddieO's Avatar
You just get the TC3 ones, they will fit the losi.....there is no losi version.
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 07-08-2004, 11:39 PM   #11490
Still Bill's Avatar
Later EddieO
The TC3 ones come in both graphite and plastic. Get the graphite ones.
Have a set of the MF aluminum hexes in my parts box. They are too wide which prevents even the nylon locking material on the low profile axle nuts from getting a good grip on the axle threads.
I only use the TC3 graphite ones on my XXX-S cars. Makes your less than 185 mm wide stock XXX-S much closer to the 190 mm legal limit. Also minimizes traction rolling on carpet tracks.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
