Old 07-05-2004, 02:38 PM   #11461
JayBee's Avatar
Trader Rating: 31 (100%+)
Default Re: Front-end problems
I'M AT A COMPLETE LOSS AND STUCK ON STUPID
any suggestions.... [/B][/QUOTE]
Well I tried something else..... I took the wheels off to see if I still had the problem, and guess what, I don't. So instead of putting the wheels back on (I kind of figured I have a balancing problem), I put just rims on instead. And whadduya know, SAME PROBLEM .
I did try to mess with all the trims last night and it fixed some centering probs I've had, but nothing else.
And the spindle suggestion, I haven't tried because the 'bump' on it is about 1.5mm from the C-hubs (carriers).
Being that nothing shakes up front when there's no weight on the axles is QUITE PERPLEXING .
I know part of R/Cing os tinkering with the car... but I'm all tinkered out. I'm ready to give up on this DAMNED CAR
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-05-2004, 06:45 PM   #11462
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Hey SoCal Guys,
Is there any racing down there this Friday? And if so where?
I'll be down there this weekend and would to do some racing.
thanks homies.
JohnMatrix is offline   Reply With Quote
Old 07-05-2004, 09:30 PM   #11463
Randy Caster's Avatar
Trader Rating: 46 (100%+)
JayBee - What rims are you using?
Old 07-05-2004, 09:45 PM   #11464
kevin2's Avatar
Send a message via AIM to kevin2
Default Re: Re: Front-end problems
any suggestions....
I know part of R/Cing os tinkering with the car... but I'm all tinkered out. I'm ready to give up on this DAMNED CAR [/B][/QUOTE]
When i first built the car had a similar problem. I didnt put grease in the right spot in the CVD, and it would lock up when it would turn to a certain spot and would lift the suspention up so every time the wheel moves the whole suspention started to shake like crazy. I put grease in the CVDs and never had the problem again. so check if the CVDs move freely.
Hope this helps.
Kevin
kevin2 is offline   Reply With Quote
Old 07-06-2004, 08:55 AM   #11465
Default G+ driveshafts
I believe my driveshafts are starting to wear where the pin goes through to hold the axle on.
I can only find part numbers to replace the whole assembly which to be honest seems expensive at 30 a pair. can I just replace the main (Light blue) part of the drive shaft as the rest seems fine?
If so whats the part number please? Or as they are MIP can I just use any MIP replacement?
I have been told I can re drill them to make new holes, any idea what size drill bit will be needed?
Rich_p is offline   Reply With Quote
Old 07-06-2004, 02:46 PM   #11466
Yes you can replace just the axle without buying the whole assembly. I don't know the part # but look @ losi's home page and you'll find it. Also IRS has an optional replacement.
Poppa Ray is offline   Reply With Quote
Old 07-06-2004, 03:18 PM   #11467
Jaybo's Avatar
there's a little pin that goes through the cvd cup segment that can somtimes work it's way out to rub against the knuckles
Jaybo is offline   Reply With Quote
Old 07-07-2004, 09:21 PM   #11468
Still Bill's Avatar
If you turn the steering all the way to the right or left you should be able to see that the tie rod will be straight on to the Ackerman (sp?) arm attached to the front hub. You don't want that condition in a real car or an r/c car. You have to have some angulation between those two components (something less than 180 degrees) to maintain the right steering geometry and eliminate the shake .
As Randy C said earlier...Limiting the steering via shims fixes the shake problem. I do what JKerr does...Which is turn down the steering on my radio.
The graphite chassis also has a forward position for mounting the steering arms. This also would helps keep the angulation below 180 degrees...especially when the front suspension arms are placed in the forward position.
Hope this helps.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 07-07-2004, 09:58 PM   #11469
JayBee's Avatar
Default Re: Re: Re: Front-end problems
Hope this helps.
It would if I had the Graph +, but I got the RTR. Is the problem/ solution the same on my car?
I'm going to have to read through Randy C's fix again also yours XXX-S Bill.
Thanks for the help guys
Old 07-07-2004, 10:25 PM   #11470
Still Bill's Avatar
Default Re: Re: Re: Re: Front-end problems
I assume that you have the JR2 radio with your RTR (as I did).
Pretty sure that the JR2 has the steering end adjustment to limit how far your steering turns.
If not, then Randy Caster's suggestion rules...As usual.
Old 07-07-2004, 10:31 PM   #11471
BadBoyRC's Avatar
Trader Rating: 2 (75%+)
ah losi mana... yes.. one setup and forget it.. like a ron popiel roster oven
BadBoyRC is offline   Reply With Quote
Old 07-07-2004, 10:40 PM   #11472
Still Bill's Avatar
Once a tweeker...Always a tweeker...
Satisfied for now though...Have to see how it pans out...
Now I just have to driiiiiiiiiiiiiiiiive...
Old 07-07-2004, 10:42 PM   #11473
Still Bill's Avatar
Talking
Doesn't the roaster oven have a timer to mess with???
Old 07-07-2004, 10:44 PM   #11474
BadBoyRC's Avatar
yeah but does it do chicken! and those pork chops.. tasty./
Old 07-08-2004, 02:43 AM   #11475
woozer71's Avatar
Trader Rating: 23 (96%+)
Default ONE WAY
Hi guys
I put a one way in my losi about 2 months ago. I have ran it about 6 times. The last time I ran the car the left hub internal bearing was totally destroyed. I was wondering if someone else has had the same problem and if so how did they fix it? And what would cause it?
woozer71 is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
