Old 07-03-2004, 10:54 AM   #11431
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
We have always ran foams on asphalt. The car needs to be a little softer than when on carpet. The cars are not as agressive on asphalt. Normally run either purple rears and purple fronts or double purple fronts. On the Losi I always ran the green springs in the front and blues in the rear with 40 to 50 wt oil and 56 pistons. Run full traction compund on the rears and the inside fronts, about a 1/4 or so and try it out. If you need a little more steering you can always use a little more compound on the front
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-03-2004, 01:45 PM   #11432
Formula1fan's Avatar
I currently run orange/purple(plaid) on my Xray. Have you ever tried those or should I just use double purple. I would love DP, because the Plaids wear so fast. I want to make the switch, becasue My xray was a headache on carpet and I plan to run the XXX-S this winter. Alot of people told me running this car in stock is asking for the B main, has the black belt made that much of a change. Thank you for your time.
Formula1fan is offline   Reply With Quote
Old 07-03-2004, 03:43 PM   #11433
Trader Rating: 37 (100%+)
I was running jaco plaid fronts and purple rears on my losi with mod motors....and the setup worked well.
for springs i just went to the green/blue combo as well....i tried running the purples up front but they were a bit to stiff at the track.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 07-03-2004, 04:12 PM   #11434
wyd
Tech Legend
wyd's Avatar
When I ran my XXX-S in stock I never lost because of running a belt car. Of all my cars the Losi was the most consistant and easiest for me to drive fast. My TC3 was good but handling was never close to what my Losi was. I'm not a Losi fan by any means as I actually don't care to run Losi stuff but I want consistant and the Losi gave me that. If your car is setup well and bearings are good and free you won't be in the B main anymore than any other car.
I have ran Plaids before. One of our faster guys always runs D Purples on his Xray. His car steers on a dime. His chassis is setup very flexable with the split toplate. Runs a pretty soft spring setup as well. Car is fast.
Brian
Old 07-03-2004, 04:42 PM   #11435
What weight fluid were you using?
Old 07-03-2004, 05:35 PM   #11436
Trader Rating: 55 (100%+)
on asphalt i've found the multi compound tyres like the plaids to be pretty useless.
40 rears and either 40 or 42 fronts is usually the safest starting point.
tones is offline   Reply With Quote
Old 07-03-2004, 05:48 PM   #11437
I know this has probably been asked, but with the black belt kit do you need to cut every other rib on the belt?
Old 07-03-2004, 05:56 PM   #11438
Randy Caster's Avatar
Trader Rating: 46 (100%+)
For tracks that require brakes with a diff or spool, leave the belt with all teeth on. For tracks with a slight amount of brakes with a 1 way cut every other tooth. For tracks with no brakes you can cut every 2'nd and 3'rd tooth. This is just what I do, it's propably recommended to leave all the teeth on, and not necissary to cut them off.
Old 07-03-2004, 06:14 PM   #11439
NVisible's Avatar
Hey Randy, where do you get your bearings for your BK Bones? I just pulled the ones out of my XXX-T and they fell to pieces
they are 3/32 x 3/16 right?
NVisible is offline   Reply With Quote
Old 07-03-2004, 08:01 PM   #11440
Just do a search on eBay for the bearing size and you should find em for a buck a pop.
Old 07-03-2004, 08:04 PM   #11441
NVisible's Avatar
Yea just found em. RCBoys has them, and theres a skateboard shop selling 10 at a time for 9 bucks, Thanks
now i gotta wait till they arrive to put my truck back together
Old 07-04-2004, 02:04 AM   #11442
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
someone was asking where they could find the Taymia shocks.
I think these are them and in stock it looks like.
Shocks
JohnMatrix is offline   Reply With Quote
Old 07-04-2004, 05:00 AM   #11443
lazyboy's Avatar
Send a message via AIM to lazyboy
Shocks
yep those are the ones, im not sure if there in stock but it sure looks like it.... anyone care to clear up the confusion on if there in stock or not?
lazy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 07-04-2004, 06:22 AM   #11444
Shev's Avatar
I'm a bit of a Pro Stock driver, but looking at going modified. What kind of roll out am I looking at for a modified motor? say about a 9 or 10 turn.
Shev is offline   Reply With Quote
Old 07-04-2004, 06:24 AM   #11445
Shev's Avatar
Are the guys at Losi working on a new touring car? Does anyone know?
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
