Old 06-30-2004, 11:44 PM   #11386
Still Bill's Avatar
Originally posted by kevin2
for 2mm of droop on a ride height gauge about how many limiters do you want in the shock?
For a definitive answer to your question, you would need to indicate which low/mid/high inner pivot supports (low, mid or high) and how you mounted the front (0F/4F or 2F) and rear (0R/4R or 2R) outer blocks for both ends of the car.
Good news is that after you play with the inside shock limiters a few times, it becomes pretty obvious as to what to use for your various setups. FYI...Low roll center setups tend to use about half the inner spacers of a high roll center setup.
You also have about 2+ full turns of the ball cups on the shock shafts to play with for fine tuning. So if you get into the right zone with the spacers, you should be able to adjust the droop from 2-5mm without having to open the shocks change the spacers
If you cut the LOSA5050 shock spacers into a "C" shape (using a Dremel or plastic snippers), it makes the process of inserting and removing them WAAAAAAAAAAAY EASIER.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 06-30-2004, 11:56 PM   #11387
Still Bill's Avatar
Originally posted by JohnMatrix
If it was not for this thread I would be driving backwards still.
Wasn't that you driving backwards on Saturday???
he, he...
You can vindicate yourself this Saturday.
Old 07-01-2004, 12:02 AM   #11388
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
thats what the B in B main stands for. LOL
JohnMatrix is offline   Reply With Quote
Old 07-01-2004, 12:54 AM   #11389
lazyboy's Avatar
Send a message via AIM to lazyboy
i thought it ment balistic?? or is that for the A-main only
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 07-01-2004, 01:10 AM   #11390
Default Thank you...
James. That is all I needed.
Nightbreed is offline   Reply With Quote
Old 07-01-2004, 12:02 PM   #11391
mwcet8k's Avatar
Default Mounting a Novak GT7
Just wondering how those of you running a GT7 in your xxxs mount the capacitor. There's not enough room to mount it on the side of the ESC, so where do you put it?
I'm torn between buying the GT7 or the LRP QC2.
mwcet8k is offline   Reply With Quote
Old 07-01-2004, 12:14 PM   #11392
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Kind of hard to see because of the black case, but there's plenty of room to mount the capacitor on the side. Just mount the switch on top.
Jon Kerr is offline   Reply With Quote
Old 07-01-2004, 12:15 PM   #11393
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I mount it behind the motor, I have the capacitor mounted on one end and the switch on the other with no problems. I have also had the same setup in front of the motor.
Old 07-01-2004, 01:13 PM   #11394
STLNFRST are you Jeff M. from Sac. area? C.J. and I met you at Reedy this year.
Charles
Charles is offline   Reply With Quote
Old 07-01-2004, 01:43 PM   #11395
Just took some new pics of my sedan with the Tamiya shocks.
Old 07-01-2004, 01:44 PM   #11396
Old 07-01-2004, 02:44 PM   #11397
JohnMatrix's Avatar
Hey Randy,
I heard you picked up an Xray, how do you like it?
Nick
Old 07-01-2004, 02:50 PM   #11398
Jon Kerr's Avatar
Hey Randy,
Nick
First I've heard of this. Care to explain Mr. Caster?
Old 07-01-2004, 04:07 PM   #11399
kevin2's Avatar
Send a message via AIM to kevin2
I think I got it right with the droop but when I set the ride height I have to crank down the shock collar all the way and it still is at 4.5mm so I moved the ball cups a little but then it wuz set at 2mm of droop in the front and 3 in the back.
kevin2 is offline   Reply With Quote
Old 07-01-2004, 10:31 PM   #11400
Still Bill's Avatar
Kewl!
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
EbbTide
