Losi XXX-S
Building A Ultimate XXX-S
Here is list what I did so far since year 2001 ORG XXX-S,
Any hting on the list you can find made my car better or worse? (any comment?)
1: Moved all my electronics forward to better balance chassis
2: Installed fan and heat sink
2: Milled down front shock upper bushings to give FR shocks better angle
3: Got rid of servo saver
4: bought many packs of GP3300 (from Sanyo 3000)
5: Start deep cycle my packs for better punch (more story later)
6: Installed set screws on rear suspension mounts to hold arms tight.
7: Dremel sharp droop screws end point round to keep droops consistent
8: Installed 0.5 Left rear hub carrier on right and 1 degree rear right hub on left side to have equal rear toe in
9: graphite conversion
10: Ceramic bearings
11: ball bearings on bellcranks
12: Aluminum CVDs
13:Kevlar spur
14: HD long black belt
15: Cut down Axles and installed trinity low profile lock nuts to save rotating mass/unsprung weight
16:Swiss cheesed front bumper
17:Full set of titanium screws
18:Titanium turnbuckles
19: last but not least Got ALFA/Mazda 6 body! (what a difference!)
20: gold plated hinge pins
กก
12: Aluminum CVDs
13:Kevlar spur
กก
This is my wish list and PIC of my ride
1: Milled down the chassis without holes.
2: Get rid of battery strap, go back to 3M strapping tape
3: Moved in battery to center of the chassis like Jukka Steenari did on his XXX-4 @ 2003 IFMAR
4:Get BK bones for FR and Rear
5:Get Team associated Blue clamp hubs to widen the width
Any NO NO? or add on for stcok class racing at SOCAL?
I guess So! Thanks James. I was told by another person that I should give them a shot and see what they feel like. So I can make a premo setup for nats. Does anyone know if we can run one ways at nationals? I guess last year there was a rule where you couldn't.
-Korey
-Korey
-Korey
-Korey
Dremeled diff cover
I did this so far to begin the journey in to files of graphite dust.
Originally posted by Randy Caster
James is the man when it comes to part #'s
Hmm, I'll be running 19T and stock. Not sure If I wanna do that. Thats adding alot of rotational weight....
-Korey
-Korey
James- it's hot man. I don't know if I can hang anymore. I'm dying in this heat. You know heat rises and dark colors attract heat so I'm twice as hot as anyone else....LOL Are you racing Wednesday? I might be coming out. If not I'll be there bright and early on Saturday.
STLNLST ...you still gonna run the sister-class?
R/C Tech Elite Member
James - I found a killer price on BK Bones bearings at a buck a pop, search on ebay 3/32" x 3/16" bearings. I bought a bunch since I replace my CVD's after every raceday, lol.
Here is the e-bay link
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V
Have bought from this guy before. Fast shipping and great customer service.
Any word if Losi is going to put out the BK bones for the xxxs? If not what are you guys doing to make your own?
Jeff
Jeff
I dont know whats up with the BK bones for the XXXS, havent heard anything about them in a while.. I've just been milling the outdrives myself.
