Old 06-10-2004, 01:05 PM   #11041
Default Re: Re: Matt Francis Setup
Originally posted by James Nguyen
No typo on the setup sheet. The high roll centers make the car drive flatter and are more responsive. They make the car not so lazy from side to side weight transfer since its rolling less it takes it less time to get back to center. It also frees the car up on high traction surfaces since there is less roll there is less traction being gained. We only use high roll centers on asphalt. Never use high roll centers on carpet.
Use one ways if you are running stock and rubber tires on carpet. You'll need the corner speed. You could use a spool but it binds the drivetrain and tears up cvds pretty quickly. Also the spool will push bad if you don't have your car setup right. The tight diff will give you more offpower steering but less onpower as it will slip just a slight amount. If you are running foams never run anything but a diff in your car.
There is an informative roll center article that futureal wrote in the latest xtreme r/c mag.
Thank you James and everyone else for your feedback. I will checkout that article.
Losi Lunatic is offline   Reply With Quote
Old 06-10-2004, 01:25 PM   #11042
Default set up reedy race 2004 losi xxxs
Hello, do you have a losi XXXS set up from the reedy race 2004?
grooveman is offline   Reply With Quote
Old 06-10-2004, 02:30 PM   #11043
Default Re: set up reedy race 2004 losi xxxs
Check back a few pages on this thread or go to gearchart.com under electric setups.
James Nguyen is offline   Reply With Quote
Old 06-10-2004, 05:28 PM   #11044
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Originally posted by Jeff Werner
Randy- you have made the change from Yokomo to Losi sedans...what thoughts do you have between the cars now that you have went back to running the losi? I am running a yok now and am thinking about going to the losi and wanted to know your insite.
Jeff
I was really struggling with the Yokomo SD in mod was usually 2 laps off the pro mod pace at SoCal, first time out with the Losi I missed the win by less than a half second... It's way easier to drive, and the same setup works pretty much everywhere it seems.
Old 06-10-2004, 08:41 PM   #11045
racer-oZ's Avatar
R/C Tech Charter Subscriber
Randy, keep in mind that your comments are about to cost Mr. Werner about $350 between now and mod nats time. lol
By the way Randy, will you be at the nats? I wouldn't mind introducing myself and bench racin with ya.
racer-oZ
racer-oZ is offline   Reply With Quote
Old 06-10-2004, 08:50 PM   #11046
I'm not sure if I'll be at Nats yet, I'll definately be at the Losi race though.
Old 06-10-2004, 08:57 PM   #11047
Korey Harbke's Avatar
Awwww come one. You gotta go to nats dude!
-Sushi Boy
Apex RC - Prospec America - Awesomatix USA - Roche RC USA - Protoform - AVID - Xpert - Sweep - Slapmaster Tools - Hebiki Design Works - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 06-10-2004, 09:13 PM   #11048
Convince ROAR to hold the nats at SoCal... I'll be all over it!
Old 06-10-2004, 10:19 PM   #11049
rtypec's Avatar
Randy, I was at Tamiya today. They have red parts so I would suggest calling customer service
rtypec is offline   Reply With Quote
Old 06-10-2004, 10:37 PM   #11050
Thanks Rod, is it 1-800-TamiyaA still?
Old 06-12-2004, 03:23 PM   #11051
i have noticed a problem on the front end of my car where the right front shock only compresses about 90% of what it should do. I have checked the shock off the car and this is not the problem, i have also checked all the turnbuckles, blocks etc and the problem is not with them either in my opinion. does anyone have any suggestions as too what the problem may be
Bony85 is offline   Reply With Quote
Old 06-12-2004, 03:30 PM   #11052
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Check that you're shock connections aren't binding. If you tighten the upper mount too much you can cause them to bind up.
Jon Kerr is offline   Reply With Quote
Old 06-12-2004, 05:55 PM   #11053
The Evicerator
Make sure that your camberlink ball cups aren't binding on your castor block.
Make sure that your CVD isn't bottoming out inside your diff/one-way.
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 06-12-2004, 06:18 PM   #11054
mwcet8k's Avatar
Does the suspension move freely through the full range of travel when you take the shock off of the car?
mwcet8k is offline   Reply With Quote
Old 06-12-2004, 07:21 PM   #11055
Also might want to check to make sure the CVD pin is still in place and not sliding out.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
