Losi XXX-S
Originally posted by JRM
I don't think they carry the D-rings but they do carry these little gems(see attached).
They replace the entire thrust bearing assembly and make diff building a lot quicker. I have been using these in losi cars for years now and they work/hold up great.
Part no: 7806K53
Part no: 7806K53
Originally posted by harris
guys what is the website of RC modeler in Hong Kong that has the Tech Racing one way???
Is there a part number for the one way bearings??
Tech Racing one-way in Hong Kong
thanks rocketron..... it is a little expensive ...
JRM, could you please tell us where we can found this thrust 7806K53????
It looks good..
It looks good..
Originally posted by STLNLST
I'm running stock and mod at the cup. What classes are you running if you go??
It looks good..
It looks good..
you can get them at www.mcmaster.com
thanks for the site....Dave
ya i remember losi using that type of bearing also.....
R/C Tech Elite Member
Originally posted by HarshGuy
Dude, I've been signed up since "day one" ...just look at the signups, I don't see YOUR name anywhere though
The Losi Molded Thrust Bearing with Hard Balls is part number A-3098 and lists for $5.00. I prefer it over the hardened carbide balls you can get from Losi; however, putting individual ceramic balls ($1.00/ball) in the diff and thrust areas gives really smooth diff action.
At $9.40, the McMaster Carr #7806K53 bearing set is almost twice the cost of the molded Losi unit.
The MC set may cost more; but, if Todd Hodge uses it, I assume they are better.
I have one XXX-S setup with all ceramic balls and the other with the molded Losi thrust bearings. Unfortunately, I have too many variables between these stocker cars to make a call one way or the other.
Hey everyone, I'm currently driving a Serpent 710 and love it but I want something elcetric. I've pretty much narrowed it down to the XXX-S with a brushless setup. What I'm wondering is if the XXX-S has any problems or quirks and if so what are the fixes?? I thought I heard once something about the steering having issues???? I personally don't know that is why I've come here to ask and learn. Thanks for your time and I hope to hear from you soon!!
If you get the graphite plus kit you can run it bone stock and be fully competitive with it. The HD belt is a good upgrade, improves acceleration and runtime.
Thanks Randy, I was planning on getting the graphite kit any way. What is this HD Belt????? Where does it go and do you have a part #??? Thanks for your time!
Regarding the steering, I think you're confusing rumors about the Associated TC3 with the xxxs. I know there are some issues with the TC3 steering, but nothing that I've ever experienced or heard regarding the xxxs.
Here's the info on the belt kit. Definitely a smart upgrade:
http://www.teamlosi.com/newprod/2004..._drivebelt.htm
