Old 06-07-2004, 09:07 AM   #10981
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by RichO
Randy: How low grip was the track? I am half wondering if this setup would help my cause in the heat. The spool (as mentioned) is not bad, but...
I am finding the tires just get too hot after 3.5 minutes and pretty soon its drift racing... Car just doesn't want to rotate without throwing it into the corner (which is half the problem). If I increase the rear rotation then it gets too loose after 3.5 mins.
It's a very low grip track. I used 36R's instead of the Take Off's and even they overheated at about 4 mins in. Fortunately I drove a lot of off-road and I can drive a way loose/pushy car.
Old 06-07-2004, 09:15 AM   #10982
Originally posted by mugenracer
Randy that was a close one, great driving. where can i find that set up? Robert
James Nguyen is offline   Reply With Quote
Old 06-07-2004, 10:01 AM   #10983
I made changes to the front end. 3.5mm droop, 4.5mm ride height, #4 in shock tower, camber #2 in shock tower, ackerman forward and flipped.
Old 06-07-2004, 11:47 AM   #10984
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
why are you guys reluctant to run a one way???? the only times i dont' are if the rules prevent a oneway or, if i have faom tires....but as a general rule, if my car has rubber tires i use the one way......period....the car is faster.....
just my opinion...
matt
Matt M. is offline   Reply With Quote
Old 06-07-2004, 02:27 PM   #10985
I didn't know I was reluctant to run a 1 way, must be in denial or something.
Old 06-07-2004, 03:15 PM   #10986
The Evicerator
if the track is hooked up 1-ways are dialed... if you're just drifting your car around a spool will make it easier to deal with
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 06-07-2004, 03:50 PM   #10987
Rockheadsguy's Avatar
Send a message via AIM to Rockheadsguy
Default Fragile one-way
I'm reluctant to use a one-way anymore because the Losi unit kept breaking... I admittedly hit stuff way too often, but the one-way would go bad with a few wall or stranded car whacks, before an arm or hub or any other part would break off. I didn't want to keep buying the replacement halves...
I did like using the one-way though-- is there a stronger one available, or a way to beef up the Losi model? Or just a way to replace the bearing, which seems to be the part that went bad?
Rockheadsguy is offline   Reply With Quote
Old 06-07-2004, 03:54 PM   #10988
I have yet to break a 1 way, but I believe it is Tech Racing that makes an aluminum one.
Old 06-07-2004, 03:57 PM   #10989
rocketron's Avatar
Trader Rating: 16 (100%+)
tech racing does make an aluminum one-way that has a larger bearing and outdrive. rc modeler in HK sells them
rocketron is offline   Reply With Quote
Old 06-07-2004, 04:11 PM   #10990
racer-oZ's Avatar
R/C Tech Charter Subscriber
I'm a big fan of the XXX-S, but I'll say that in my experience the one way is fragile. I've resigned myself to a spool or diff, and I am going to keep a oneway in my box to only use when I'm getting beat by a field of one ways. I've had two bearings in the one way go bad after just a few weekends of running them.
racer-oZ
racer-oZ is offline   Reply With Quote
Old 06-07-2004, 04:30 PM   #10991
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
The only o-way I broke was the one I put in my xxx4 buggy.
Jon Kerr is offline   Reply With Quote
Old 06-07-2004, 04:35 PM   #10992
rocketron's Avatar
racer-oZ
i've had many bearings come apart (break) and since i've used a very good quality light weight oil in them have not (knock on wood) had any further trouble. but have strongly considered getting the tech one-way.
Old 06-07-2004, 09:33 PM   #10993
racer-oZ's Avatar
rocketron, what oil are you using on your one way bearings? I was always under the understanding we were supposed to use a small amount of grease on them. Maybe that's my problem? Interested to hear more thoughts on this because I do like the feel of the oneway in certain situations.
racer-oZ
Old 06-07-2004, 09:51 PM   #10994
I know XRay makes some 1 way lube thats supposed to be good.
Old 06-08-2004, 12:06 AM   #10995
rocketron's Avatar
racer-oZ
there are a couple of oils said to be for one-ways but i've been using marvel mystery oil. i don't know if everyone would agree on that being a quality oil but i've not had a one-way bearing go bad in the last 4 to 5 months sense i started doing this. just a drop or two every 4 race days or more.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
