Old 06-05-2004, 10:03 AM   #10966
Thanks Tones I'll give that a try....
Key500 is offline   Reply With Quote
Old 06-05-2004, 10:11 AM   #10967
mwcet8k's Avatar
Hey Randy, what kind of ESC is that?
mwcet8k is offline   Reply With Quote
Old 06-05-2004, 10:26 AM   #10968
Post Quick question time....
I have the XXX-s G+ as one of my choices of on-road car to run 540 stock so I'm wondering does the spur gear adapter I have seen change the internal ratio of the car because it looks like (but I can't tell for sure from blurry picture) that it has 24 teeth on it which would change the internal ratio to 1.75 I believe.
True?
Mabuchi540 is offline   Reply With Quote
Old 06-05-2004, 11:59 AM   #10969
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by RichO
Randy: No problem. I used to race there many years back. Definitely a different type of track. The glitching problem you mentioned is interesting. I had a similar problem on the track here, but have messed around with the antenna and managed to get it corrected (I think - watch me plant it in the wall today...)
Unfortunately in controlled practice I didnt have time to try and find the problem. I just stripped the car of its electronics and threw all new ones in and made sure they were spaced out.
Old 06-05-2004, 12:51 PM   #10970
dougmartin's Avatar
Trader Rating: 14 (100%+)
Thumbs up Set-up help
Was wondering if someone could help me out with a set-up for ashphalt. Been over a year since I hit the pavement. XXXS G+ with a oneway. I'll be running mod and 19t. Tire choice I'll be using is sorex.
Pic of the track I'll be running on
dougmartin is offline   Reply With Quote
Old 06-05-2004, 12:55 PM   #10971
mwcet8k's Avatar
That looks like an awesome track. Which one is that?
Old 06-05-2004, 01:01 PM   #10972
dougmartin's Avatar
Thanks. It's located in Kamloops British Columbia,Canada.
We also have a dirt track right beside it on the left of the picture.
Old 06-05-2004, 01:14 PM   #10973
NVisible's Avatar
thats it, im moving to bc.
NVisible is offline   Reply With Quote
Old 06-06-2004, 07:51 PM   #10974
The MF Reedy setup works awesome on low grip smooth asphault Missed Chris Tosolini's TQ in pro mod by 1 second today
Old 06-07-2004, 02:12 AM   #10975
woozer71's Avatar
Trader Rating: 23 (96%+)
Can someone tell me the number for grahite bellcranks if you can get them?
woozer71 is offline   Reply With Quote
Old 06-07-2004, 06:09 AM   #10976
RichO's Avatar
JKerr -> YGPM. I am playing with the spool but still messing with the idea of using either the very very tight diff or one-way. I must say that some of your idea's, mixed with Hodapp's setup from last year yielded the fast time of the weekend, but the car deteriorates late in the run as the tires heat up.
RichO is offline   Reply With Quote
Old 06-07-2004, 08:25 AM   #10977
Not made, they would just be brittle and break I'd think.
Old 06-07-2004, 08:49 AM   #10978
Randy that was a close one, great driving. where can i find that set up? Robert
mugenracer is offline   Reply With Quote
Old 06-07-2004, 08:56 AM   #10979
I know Matt gave the sheet to Todd, and I believe Todd is going to post it on the Losi site. I just wish I would have switched to it at Reedy.
Old 06-07-2004, 09:03 AM   #10980
RichO's Avatar
Randy: How low grip was the track? I am half wondering if this setup would help my cause in the heat. The spool (as mentioned) is not bad, but...
I am finding the tires just get too hot after 3.5 minutes and pretty soon its drift racing... Car just doesn't want to rotate without throwing it into the corner (which is half the problem). If I increase the rear rotation then it gets too loose after 3.5 mins.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
