Losi XXX-S
Originally posted by Randy Caster
woaaah, you guys dont use a 1 way out there? I'm gonna be slow again at the Losi race if there isn't a 1 way up front...
R/C Tech Elite Member
Spools definately suck, I'm really not all that great at hitting the brakes. I'm gonna give it another shot with a front diff this weekend though.
I am curious what kind of setup changes are you guys making between going spool versus one-way versus diff.
I have always driven a diff but trying to get used to the spool. The track here is long straights, big sweepers and 4 tight turns.
The push is a pain but I figure I will get it sorted out this weekend.
Haven't tried the one-way for ages and I am a little surprised you guys like them so much.
-Rich
PS: Randy, I'm with you on the brakes. I rarely use them but better figure out how.
-Rich
A lot of guys were using a lot of brakes at the Reedy race. It was the fast way through at least one spot. It's not as much of a finesse (sp?) driving style. There were a lot of clicking belts going into the hairpin after the sweeper.
Fellas...I have 2 questions. First, do any of you run a small fan for motor cooling? If so, where and how did you mount it? Second, I just picked up a Bianary2 stocker today and was wondering ballpark on the gearing. 100 ft straights flowing turns and around 12.5 secs. per lap. I run 64 pitch BTW.
Brant
Brant
Losi Drive System
Is there anyway to get the Losi drive system to spin more freely
or to spin freely at all you know like when I put the car on ground and if I push or barely it doesn't roll forever, is this normal for a Losi sedan, I mean when I'm on the track it seems ok, I don't know but always have had 4wd nitro cars and those cars would coast very very freely... Can someone please help me out.
Thank you
Thank you
repost for key500.
it may or maynot apply... just somehting to check out.
my car is tonns freer since having found and corrected the following.
dont know if this is old news or whatever but it's just something i've recently found and fixed with my car:
i found my losi was damaging bearings pretty bad, motors were over heating and was having to under gear them severly etc. just excessive friction in general.
which i tracked down to the hex/axle/bearing area.
tried different oils for the bearings, running extra spacing between the bearings thinking they were being pinched due to there not being enough spacing between them, also not tightening wheels down too hard (leads to wobbly wheels anyhow), etc. but it still keept happening.
finally worked out that between the hex and the shim between the bearing and the pin for the hex that they were pushing the hex out over the threads and making it easy to overtighten and pinch the bearing.. or i guess even cornering loads on the track could also have a greater effect on the bearings.
to fix i took out the shim and used a thinner shim from LOS6230 Losi, SHIMS ASSORTMENT (20) 2.50.
just something to look at, especially if you find your hub bearings bind up as you tighten your wheel nuts.
Brant
Brant
Originally posted by STLNLST
I was going to run a regular diff this weekend but I'm not racing mod. In stock I think the oneway is faster. James and I are going to play around in the stock class this weekend. Corner speed is a must in stock and that's where the oneway comes in.
Randy: Is there a good base setup for 19T (or I assume stock will be much the same) that you have tried and liked?
General question: Are you guys still stacking the electronics in front of the motor or are people reverting back to putting the esc behind the motor again? I am curious how others have found the handling changes with this.
I put the ESC in the back of the car again just because I had glitching problems at Tamiya with it in front.
Randy: No problem. I used to race there many years back. Definitely a different type of track. The glitching problem you mentioned is interesting. I had a similar problem on the track here, but have messed around with the antenna and managed to get it corrected (I think - watch me plant it in the wall today...)
Here's how to mount the fan.
Brant
