Old 05-22-2004, 06:58 AM   #10741
HarshGuy's Avatar
James, thanks for the help yesterday ...will be putting the schuey and related parts up for sale later on this weekend, well at least I won't be thinking "what if" later on
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 05-22-2004, 05:12 PM   #10742
STLNLST's Avatar
Trader Rating: 19 (100%+)
you will be when I race in your class for the speedworld cup.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-22-2004, 06:06 PM   #10743
HarshGuy's Avatar
LOL ...well unless you're racing stock or 12th I guess I won't be saying "what if" ....James, what oil were you using? I didn't write it down and I forgot (memory's the 1st thing to go).
Old 05-22-2004, 06:54 PM   #10744
60wt with 56 pistons.
James Nguyen is offline   Reply With Quote
Old 05-22-2004, 07:21 PM   #10745
Trader Rating: 28 (100%+)
Hey James,
Thats your setup on Ruben's car right? Man that thing was so railed today. I drove it in practice. The car is so easy to drive.
How much of a difference did going to the black belt really make?Would you say it make the car perform completely different?Last time I drove a losi,it never felt that good.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-22-2004, 09:18 PM   #10746
Originally posted by racenut123
Hey James,
That's a setup I put on his car, mine is a little different now since racing on the current speedworld layout. I would say you can easily tell the difference from running the yellow and black belts back to back. It's nice because you can run the belt loose to keep the drivetrain free and still have good snap off the corner. It definitely makes the car accelerate different than it used to.
Old 05-22-2004, 10:30 PM   #10747
Default more suggestions
i took your guys advice and put the black belt kit in, man what a pain. what r the other must have mods. i'm wondering about gearing. i am racing indoor on carpet i would say it's a fairly open track, but no major long straits. how important do you think front or rear sway bars are?
e money is offline   Reply With Quote
Old 05-23-2004, 12:01 AM   #10748
Korey Harbke's Avatar
Swaybars are really nice when the traction gets really high at rain city. During the regular carpet season the traction gets to an unreal level. I just ran today and I ran a very thin swaybar all around to keep the body roll down a bit.
-Sushi Boy
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-23-2004, 02:18 PM   #10749
Cardboard's Avatar
Send a message via AIM to Cardboard
Default front hub carriers
has anyone noticed that the graphite front hub carriers are very weak around the bottom screw area? i've broken three this way in my short time of owning an xxx-s and it's beginning to annoy me. i attached a picture to show what i'm talking about:
Cardboard is offline   Reply With Quote
Old 05-23-2004, 02:41 PM   #10750
JDXray's Avatar
Send a message via AIM to JDXray
thats why i sold my LOSI , you going to willis next saturday?
JDXray is offline   Reply With Quote
Old 05-23-2004, 02:45 PM   #10751
lazyboy's Avatar
Send a message via AIM to lazyboy
i never had that problem when i had my losi
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 05-23-2004, 02:45 PM   #10752
Cardboard's Avatar
also, i could use some help with my setup. i want slightly more rear grip but haven't found a way to achieve it yet. whatever i have adjusted was overkill(too much rear grip). here's the setup, fairly tight carpet, normal grip.
front:toe out=1
4mm ride height
-1 camber
low roll center
2 degree carrier
droop=2mm
pivot support=4
arms spaced very slightly back(.010")
ackermann=back
chrome camber ball stud
no washers under spindle, bellcranks, or camber ball studs
upper shock mounting location=2
camber link position=2
Shocks:60 wt oil, #56 piston, Purple Spring, .50 internal limiters
-jaco dbl pinks,24mm, 56mm diameter, 1/3 coverage of TQ traction compound
rear:toe in=2
ride height=4mm
camber=2
droop=4
pivot support=0
no washers under camber ball stud
chrome ball stud
arms spaced forward slightly(.010")
camber hole in hub=A
lower shock mounting location=outside
arm/hub mounting position=standard
low roll center
camber hole=1
upper shock mounting=3
shocks:80 wt oil, 55 piston, green spring
-jaco 24mm dbl pinks, 56mm diameter full coverage of TQ traction compound
body:HPI lotus elise(never buy it!!!!!!)
Old 05-23-2004, 02:47 PM   #10753
JDXray's Avatar
you have Dbl pinks all around? try dbl pink and dbl purple. works great for me at willis.
Old 05-23-2004, 02:49 PM   #10754
Cardboard's Avatar
it's closed next saturday, opening back up first saturday of june, i think. pssh.
i went to the irs race today and did terrible. those damn hub carriers took me out of the qualifers twice, even though it's not like i was doing even close to well.
Old 05-23-2004, 02:50 PM   #10755
Cardboard's Avatar
dbl pink in front? btw where were you today? last big race of the season.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
