Old 05-19-2004, 09:16 AM   #10696
imjonah's Avatar
Default tires scraping body?
I have had a hell of a time mounting a body in such away that it does not interfere with my tires.
My car came with these metallic blue nuts at the end of the drive shafts where the wheels seat. Is that my problem? Do the make the chassis to wide for standard 190mm bodies and/or require special mounting or cutting of wheel holes in lexan bodies?
On a related note where do you attach the handout transponders on your cars?
imjonah is offline   Reply With Quote
Old 05-19-2004, 09:27 AM   #10697
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
The blue hexs make the car 190mm. I've run the AE hexs since I first got the car.
With house transponsors I like to run mine behind the servo. At the base of the front window is fine too.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 05-19-2004, 09:27 AM   #10698
mwcet8k's Avatar
Are you saying you haven't cut out holes for the wheels??? I'm not quite following you. You definitely need to cut the body so that there is clearance for the wheels just like a full-size car.
mwcet8k is offline   Reply With Quote
Old 05-19-2004, 09:34 AM   #10699
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
It is possible to mount a body and not have the tires rub with the AE hexes, but you have to be dead nuts on. I've got one body that was about 1mm off in the rear and it rubbed on the left side bad. To make it easy, run a Losi body. They have the mounting dimples there for you.
Jon Kerr is offline   Reply With Quote
Old 05-19-2004, 09:37 AM   #10700
mwcet8k's Avatar
Never mind. I'm following now. Yeah, sounds like the body is slightly off center.
Old 05-19-2004, 11:38 AM   #10701
Originally posted by HarshGuy
James, do you have the setup you use for 19 turn @ SWR available? ....or are you gonna be out there Friday?
I have to write it down on a setup sheet, I'll be out there all weekend starting friday.
James Nguyen is offline   Reply With Quote
Old 05-19-2004, 11:42 AM   #10702
HarshGuy's Avatar
Ok ...I'll be there Friday
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 05-19-2004, 11:50 AM   #10703
Did you finally put the Schuey back in the Schubox in the closet?
Old 05-19-2004, 11:59 AM   #10704
HarshGuy's Avatar
LMAO ...schubox!!! ...no not yet, but it's time for it to "put out or get out" so it's "head to head" time on Friday.
Old 05-19-2004, 12:43 PM   #10705
Cardboard's Avatar
Send a message via AIM to Cardboard
is it normal to have some play in the upper shock mounting location between the nut and the bushing? I used to just crank down on the metal nut to eliminate that but i can't crank down on the nylon nuts( ) anymore.
Cardboard is offline   Reply With Quote
Old 05-19-2004, 12:50 PM   #10706
mwcet8k's Avatar
You actually want there to be some play so that the shock can rotate freely at the upper mount as the suspension compresses. If you crank the nut tight enough that there isn't any play, it's too tight. I tighten just to the point that it is snug and no more.
Old 05-19-2004, 04:23 PM   #10707
Randy Caster's Avatar
Trader Rating: 46 (100%+)
You gonna have a setup for me if I come up to the SW Cup?
Old 05-19-2004, 05:08 PM   #10708
Yeah!
Old 05-19-2004, 05:10 PM   #10709
Jon Kerr's Avatar
When's the SW Cup?
Old 05-19-2004, 05:43 PM   #10710
JayBee's Avatar
Post
I CONCUR
JayBee is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
