Old 05-18-2004, 08:07 AM   #10681
rtypec's Avatar
Originally posted by Randy Caster
Be interesting to see who it is this year.
I think the trophy girl is gonna be Miss Becky...
See Miss Becky and other hotties here
Are you going to Socal tonight? I'll be there to shop and maybe heckle. Me thinks there might even be a Dave sighting...
rtypec is offline   Reply With Quote
Old 05-18-2004, 09:21 AM   #10682
rocketron's Avatar
Trader Rating: 16 (100%+)
i think a double Dave sighting could occur........
rocketron is offline   Reply With Quote
Old 05-18-2004, 10:39 AM   #10683
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'm taking the day off, I got 2 XXXS's that are completely torn down, just took everything off the chassis I've been running to throw a new chassis on the car, just waiting on my order from Acer to come in so I can get em built. I dont think I'll be racing before Reedy.
Old 05-18-2004, 08:56 PM   #10684
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Im going to be getting a new chasis this week too.
what do i use to tap the holes?
and for different size holes do i use different size screws?
I heard someone use dishsoap, dipping screw in that before screwing it in.
JohnMatrix is offline   Reply With Quote
Old 05-18-2004, 08:58 PM   #10685
I just use a steel screw to tap the holes personally, once I get them in as deep as I'd like, just turn it back and forth until it frees up a hair then back it out.
Old 05-18-2004, 09:02 PM   #10686
JohnMatrix's Avatar
awsome, and for each size of screw you have a steel one for the tap?
not one screw for all the holes, right?
Old 05-18-2004, 09:19 PM   #10687
You can do the whole chassis with 3 1/2 x 4-40 cap head screws. Use them to tap 1 hole each in 1-2-3 order so they have time to cool down between holes. I just finished tapping a chassis a couple mins ago and it worked fine.
Old 05-18-2004, 09:19 PM   #10688
I just use a 4-40 tap and tap it about 3/4 of the length. Then when putting your screw in put some white losi grease on it and thread it in.
James Nguyen is offline   Reply With Quote
Old 05-18-2004, 10:38 PM   #10689
Still Bill's Avatar
I do almost the same as James. Tap the 4-40 size holes about 2/3 to 3/4 through the hole (depending on its depth); but, scrape threads of screw over stick of soap or ski wax.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 05-18-2004, 10:42 PM   #10690
JohnMatrix's Avatar
thanks everyone, ill pick it up this week.
Is it called a 4-40 tap screw or just a 4-40 head screw.
Old 05-18-2004, 10:53 PM   #10691
Still Bill's Avatar
Randy apparently uses a cap head screw while James and I use a tap (tool) which fits into a handle for ease of use.
When I used a screw (no pun) to cut threads, I would screw it part way in and then back it out 2-3 times to clear the graphite debris from the hole while cutting the threads.
Randy's method of using three different screws (to allow for cooling) is his typical genius showing through.
Old 05-18-2004, 10:57 PM   #10692
Still Bill's Avatar
Oh....This may count for something.
Just remembered that Randy uses aluminum screws. Not sure about James. I use titanium or stainless which seem to vary in their snugness within the same 4-40 tapped hole.
Old 05-19-2004, 01:22 AM   #10693
I use all of the stock steel screws. The only parts that have been replaced by Lunsford Ti are the 8 shock tower ones, the 4 servo mount ones, 4 shock mounts in favor of Lunsford quicktune, and 12 losi Ti ballstuds. Even with all of my MF aluminum parts on the car it is WAY under weight.
Old 05-19-2004, 05:41 AM   #10694
HarshGuy's Avatar
James, do you have the setup you use for 19 turn @ SWR available? ....or are you gonna be out there Friday?
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 05-19-2004, 07:53 AM   #10695
The fastener express screws seem to be a hair undersized, so I think a tap might be a little overkill for them, that's why I have stuck to the cap head screws...
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
