Old 05-14-2004, 09:29 PM   #10651
mwcet8k's Avatar
Yeah, definitely check out the Todd Hodge thread. Very helpful.
I wouldn't worry about the trend at your track. I've found that a lot of tracks work that way...popularity will shift from one car to another for sometimes unknown reasons. Some people just want to run the latest car out there.
The xxxs is still a very competitive car, especially with the new black belt kit. FYI, that's one upgrade you should definitely get if the kit you bought didn't already include it.
mwcet8k is offline   Reply With Quote
Old 05-14-2004, 09:30 PM   #10652
mwcet8k's Avatar
One more thing regarding setups. Check out the setup sheets posted on Losi's website. These are the setups the team drivers use.
http://www.teamlosi.com/setups/xxxs_plus/index.htm
Old 05-15-2004, 01:42 AM   #10653
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally posted by James Nguyen
Clint - What day are you guys leaving for Reedy?
we are leaving on wednesday the 26th. We should get there around 4:00pm or so. When are you heading down?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-15-2004, 04:49 AM   #10654
I believe I am heading down there on that thursday for pit b*tch duties.
James Nguyen is offline   Reply With Quote
Old 05-15-2004, 06:21 AM   #10655
HarshGuy's Avatar
I've also got all those loaded at http://www.gearchart.com as well as other cars setup sheets ...in fact if anyone is interested in beeing a setup admin, there's a link to fill out to get a login.
http://www.arroyoc.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 05-15-2004, 09:47 AM   #10656
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I'll be heading up Early Saturday morning and we'll check @ the hotel after practice. I wonder how they're going to handle the pit bit*h situation with us all having to get pit passes this year?
Jon Kerr is offline   Reply With Quote
Old 05-15-2004, 05:40 PM   #10657
mwcet8k's Avatar
Default Screwing Shock Ends On/Off
Anyone know of a good way to do this without scratching the shock shaft? I'm doing this to adjust droop, so I don't want to disassemble the entire shock. I know a company makes a tool specifically for this, but the price is a little steep I think.
Old 05-15-2004, 05:45 PM   #10658
Jon Kerr's Avatar
I take a pair of wire cutters, (dikes) and grab the shaft by the very top thread. This way if it does slip slightly, it won't effect the surface.
Old 05-15-2004, 09:08 PM   #10659
RichO's Avatar
Sushi: Thanks for the notes a week back. I have the car working quite well, even with the heat. I basically ended up with a little bit softer (spring wise) setup than Hodapp's setup from last summer. The only differences are the oil (45F-30R) and springs (blue-F, silver-R)
Rich
RichO is offline   Reply With Quote
Old 05-15-2004, 09:18 PM   #10660
mwcet8k's Avatar
That's a really good idea. Thanks.
Old 05-15-2004, 10:15 PM   #10661
Still Bill's Avatar
Jon,
I have seen too many shock shafts break at the exact location you are describing. I pushed the shaft into the shock and found a fair amount of still exposed surface to grab with hobby pliers ($5) without using dikes on that weakest location of the shaft.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 05-15-2004, 11:26 PM   #10662
Jon Kerr's Avatar
That's a good point. But I haven't had one yet. (Knock on wood.) Besides, I usually don't have much problem getting it to turn so I'm not really putting that much pressure on them. Not enough to cut a week spot into the shaft.
Old 05-16-2004, 12:35 AM   #10663
Randy Caster's Avatar
Trader Rating: 46 (100%+)
You bet man, see ya bright and early on Thursday morning
Old 05-16-2004, 09:10 AM   #10664
Cardboard's Avatar
Send a message via AIM to Cardboard
are you supposed to shim up the slop in the arm between the pivot block and main block?
Cardboard is offline   Reply With Quote
Old 05-16-2004, 10:17 AM   #10665
yeah, just use motor shims.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
