Old 05-12-2004, 09:52 AM   #10591
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Nearest track to me is over an hour away. Sucks living in the middle of nowhere.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 05-12-2004, 11:08 AM   #10592
NVisible's Avatar
well thats screw #2 broken off in my chassis. Ill never fucking ever buy aluminum screws again. why they are even made is beyond me. I even had enough hanging out that i should have been able to just grab it with pliers and twist it out. but no, aluminum is too soft and it just twisted and snapped off.
NVisible is offline   Reply With Quote
Old 05-12-2004, 11:12 AM   #10593
Thats why I use TI
Old 05-12-2004, 11:12 AM   #10594
You should try grease on the screw next time.
James Nguyen is offline   Reply With Quote
Old 05-12-2004, 11:16 AM   #10595
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I use aluminum screws all over the car and never had a problem with snapping or bending... you gotta tap the holes well and not put too much torque on the screw.
Old 05-12-2004, 11:17 AM   #10596
NVisible's Avatar
thing is, i really shouldnt have to (grease i mean). the stainless kit i have worked just fine. This alum set was fine, they went in with no trouble at all. I even set them in loose. I was taking them out to change bearings and the head snapped off one for the read diff cover. the holes have been well used as i have taken the car apart alot. like i said, they went in super easy, for some reason some didnt like to come out :shrugz:
Old 05-12-2004, 11:28 AM   #10597
When using aluminum you do have to use grease, you are going to a way soft screw... You know what happens now if you dont use grease on the threads.
Old 05-12-2004, 11:33 AM   #10598
Using such a soft screw and no grease will make it snap pretty easily. The grease doesn't just help with the smoothness it should also help with the heat created when you screw it in and out.
Old 05-12-2004, 11:46 AM   #10599
NVisible's Avatar
true enough, i didnt think of the heat aspect of it
Old 05-12-2004, 12:23 PM   #10600
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
A tip I got a long time ago with AL screws is to use chapstick. Tap the hole first then touch the screw thread on the chapstick and you're all good.
Jon Kerr is offline   Reply With Quote
Old 05-12-2004, 12:58 PM   #10601
Kwikvdub's Avatar
Trader Rating: 89 (100%+)
Send a message via AIM to Kwikvdub
Thanks Randy! When is the best time to go watch touring action over at So-Cal Raceway?
What is there website??
Alex Valdes
TQRacing / 360 v2 RC Raceway
Kwikvdub is offline   Reply With Quote
Old 05-12-2004, 01:13 PM   #10602
Saturday is the best time to go, they race at 6pm and since Reedy is coming so close, there will propably be at least a full heat of pro mod and a couple heats of 19t. socalrc.com
Old 05-12-2004, 01:15 PM   #10603
Kwikvdub's Avatar
Hey Randy!!!!!..............Thanks. Can't wait to get down there!
Alex Valdes
Old 05-12-2004, 01:22 PM   #10604
NVisible's Avatar
you guys see these:
http://www.teamlosi.com/newprod/2004...-shortneck.htm
whats the advantage of the short neck, other than space?
Old 05-12-2004, 02:12 PM   #10605
These balls aren't as tall as their old ti balls. I believe their old ti ball studs were like a black ball stud. I'm guessing these are similar in height to the silver ball stud.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
