Old 04-30-2004, 02:29 PM   #10396
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Default Re: New Belt Kits
Originally posted by clinttredway
I just picked up some parts and my LHS has the new kits in stock.. they have 4 of them.. If anyone wants them let me know...
They are 19.95...
YGPM
Jon Kerr is offline   Reply With Quote
Old 04-30-2004, 02:30 PM   #10397
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 3 (80%+)
Send a message via MSN to clinttredway
Default Re: Re: New Belt Kits
Originally posted by jkerr0043
YGPM
YGPM
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 04-30-2004, 02:36 PM   #10398
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
anyone try those AE graphite Dog Bones?
I will be this weekend, seem very nice.
JohnMatrix is offline   Reply With Quote
Old 04-30-2004, 02:39 PM   #10399
Cardboard's Avatar
Send a message via AIM to Cardboard
Originally posted by wcoyote
I'm also having trouble screwing on the plastic spring load collars. I get pretty much to where the collar has threads showing barely above it and it's too tight to turn by hand. It went on fine until that point. To my knowlege it isn't cross threaded.
i had the same problem, scrape the threads(on the collar, not shock body) with a hobby knife or xacto 'till it's manageable.
Cardboard is offline   Reply With Quote
Old 04-30-2004, 02:44 PM   #10400
Jon Kerr's Avatar
Are you running mod or stock? When I ran a TC3, I couldn't run them in mod or even 19 turn. They wore out so fast from the torque and in mod, they'll just snap. May be a good option in stock though.
Old 04-30-2004, 03:43 PM   #10401
Juan Valdez's Avatar
John,
How are you getting the AE bones to fit? When I broke a CVD and tried to use a buddy's spare TC3 bone, it didn't work. The Losi diff outdrive was too big in diameter for the pin on the AE bone. Just curious. Let us know your findings. Good luck!
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05
Juan Valdez is offline   Reply With Quote
Old 04-30-2004, 05:05 PM   #10402
Randy Caster's Avatar
Trader Rating: 46 (100%+)
He was saying that when he ran the TC3 the bones were weak...
Old 04-30-2004, 06:36 PM   #10403
Josh Numan's Avatar
Well two good things. Got my Trans Am back from the carburator shop. The new engine and carb setup really made the thing a missle.
Next my XXX-S: Been starting the shocks. What do you guys usually set the length of the shocks to for asphalt/concrete? I'm also having trouble screwing on the plastic spring load collars. I get pretty much to where the collar has threads showing barely above it and it's too tight to turn by hand. It went on fine until that point. To my knowlege it isn't cross threaded.
Ok for the shock collers here is what you need to do,get the shock coller threaded to where all the threads are over the body then get a pair of pliers and pinch the shock coller,just make sure not to pinch them to much as you can bend the aluinum shock body. when you do that it makes the threads a lo t easier to turn. This also works with turnbuckles,like say if you are adjusting your camber and your ballcup keeps popping off or its really hard to turn then get a pair of pliers and pinch the threads and you will notice a big difference in how easy it is to turn or adjust.
Let me know if that all makes sense,and if it works for you.
Josh Numan
Josh Numan is offline   Reply With Quote
Old 04-30-2004, 06:38 PM   #10404
Josh Numan's Avatar
Originally posted by Randy Caster
It's on Sunday man, Nate will hook us up with power and shade, all you gotta do is show up! I can pick you up, but wont have enough room for Jen if she wants to go...
But will you have enough room for a table??? i might get swandogg and weissdawg to go so i might be able to get my stuff and hers to fit,she wants to race....o boy
L8
Old 04-30-2004, 07:05 PM   #10405
bballer's Avatar
Hey, all, my 1st post in the xxx-s thread whohoo. Anyway, Im reading throught the thread and haven't found the answer to my question: What is the size of the stock orange spur gear and the xxx-s G+. My novak dually doesn't fit where recommended. I was thinking if i can get a bigger spur gear then my motor will be further to the left and away from my esc. Is that a good solution to this problem? Thanks
ps Right now im running a monster stock and the esc barely fits when thats installed. When I run mod, I run out of room completely. Thanks for your time
bballer
bballer is offline   Reply With Quote
Old 04-30-2004, 07:54 PM   #10406
mwcet8k's Avatar
I run the same ESC. You've got to stand it up on its side. I've attached a pic of my setup so you can see what I mean. Make sure you thoroughly clean both the chassis and the ESC before you apply servo tape, since the tape has less surface area to hold onto. Once you do that, it will stay securely in place.
mwcet8k is offline   Reply With Quote
Old 04-30-2004, 07:58 PM   #10407
bballer's Avatar
Then aren't you going to have a big difference in center of gravity? I love all my cars to be low
Old 04-30-2004, 08:05 PM   #10408
L8
That would be sick if you get em to come out, Nate should have enough power, he always does...
Just bring out a buggy for her to run in gearbox, she'll still have fun running over pipes and crap, lol.
Old 04-30-2004, 08:06 PM   #10409
mwcet8k's Avatar
Yeah, it will make a small difference in CG, but probably not enough for the typical driver to notice. My next big purchase is an LRP QC2 - it's lighter and easily small enough to fit flat in the xxxs.
Old 04-30-2004, 08:07 PM   #10410
It will be a higher CG but since you have a big ESC there isnt much choice... unless you are an expert driver you'll propably never notice the difference in CG anyway.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
