Old 04-28-2004, 03:21 PM   #10351
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Originally posted by jkerr0043
You're more than welcome to.
Especially if you bring your spares. Remember to bring a cash register, because between what you and I have, we'll open a hobby store at Reedy
Old 04-28-2004, 03:53 PM   #10352
I'll bring more than enough spares to build a FEW cars and then some!
James Nguyen is offline   Reply With Quote
Old 04-28-2004, 04:23 PM   #10353
Yep, we should definately open shop at Reedy
Old 04-29-2004, 06:42 AM   #10354
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 3 (80%+)
Send a message via MSN to clinttredway
Default Practice
I am finally going to get to try the car with new bearings in it.. The car has freed up a lot now...
Belt tension question... how tight/loose should the belt be run?
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 04-29-2004, 06:49 AM   #10355
RandyB's Avatar
I have always found in stock I ran the belt as loose as possible after a few runs just tightend a tad to get the belt from skipping during hard breaking
RandyB is offline   Reply With Quote
Old 04-29-2004, 06:51 AM   #10356
Thanks Randy! I will loosen it just a bit today.. Can't wait to drive it!
OT - I ordered a Team1 RC monster motor and should have it today... has anyone run one of these? If so, did you like it?
Old 04-29-2004, 07:44 AM   #10357
mikejr718's Avatar
Send a message via ICQ to mikejr718
Just purchased and assembled xxx g+ after running tc3 for over 1 year. Was wondering if there is a noticeable performace difference between the cut yellow belt and the new black belt kit. When I built the car I cut every other tooth off of the yellow belt as the black belt kits are hard to find. The car will be raced mostly in stock class.
mikejr718 is offline   Reply With Quote
Old 04-29-2004, 07:47 AM   #10358
I installed my black belt and I was almost a second faster a lap.. I think that it helps but my bearings were bad and I will be driving my car with new bearings at lunch today...
A guy I race with put a black belt in his car and said that he could definitly tell a difference... we both race stock.
Old 04-29-2004, 08:10 AM   #10359
rocketron's Avatar
Trader Rating: 16 (100%+)
the cut yellow belt works nearly as well as the new black belt. but suggest you keep an open eye for a black belt kit.
oh then cut every other tooth off that as well - especially in stock
rocketron is offline   Reply With Quote
Old 04-29-2004, 08:26 AM   #10360
mwcet8k's Avatar
Really??!!! It's amazing what a difference the new belt kit makes. I'm hearing nothing but good things about it.
What's the best way to cut the teeth off of these belts?
mwcet8k is offline   Reply With Quote
Old 04-29-2004, 08:29 AM   #10361
If you are going to cut a belt, use fingernail clippers...
As far as clipping the black belt, there are mixed results.. I would try it uncut first and then if want, clip it..
I think I would have noticed a bigger difference if the bearings in my car were better when I drove it..
Old 04-29-2004, 09:31 AM   #10362
RandyB's Avatar
ok I found these spur gear adapters alittle while ago and was curious to see if anyone has tried them yet they are made by jet and come in 23t and 24 tooth I wonder what advantages they offer and really would like to know if any one has seen them close up could tell me how many mounting point they have ie howmany srcew go through to attach the spur.
picture posted
oh and how many teeth are on the factory spur/pully
Old 04-29-2004, 09:37 AM   #10363
I notice a slight difference between the cut yellow belt and the cut black belt, but it is slight. I dont know that it'll be any faster on the track because of the belt, but there is less drag brake with the black belt which makes it easier to drive with a 1 way.
Old 04-29-2004, 09:39 AM   #10364
RandyB's Avatar
any problems running cut belt in mod sedan like an 8turn?
Old 04-29-2004, 09:58 AM   #10365
Holds up to 6 turns fine for me.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
