Old 04-22-2004, 12:03 PM   #10141
Originally posted by clinttredway
Here is what I am running ATM:
front:
new yellow springs 56 50wt
.080 sway bar
plaid TRC 59mm
rear:
new orange springs 56 50wt
no sway bar
purple TRC 59mm
the car doesn't really rotate at all either, in fact today its pushing
big front sway bar will make it push, post your full setup on here with everything.
James Nguyen is offline   Reply With Quote
Old 04-22-2004, 12:07 PM   #10142
RandyB's Avatar
You must be a wizard to do that with a dremmel especially on the sides on the tunnel
RandyB is offline   Reply With Quote
Old 04-22-2004, 12:25 PM   #10143
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 3 (80%+)
Send a message via MSN to clinttredway
Here it is..
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 04-22-2004, 12:36 PM   #10144
i can barely read anything on that. could you type it out?
Old 04-22-2004, 12:38 PM   #10145
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Like I said earlier, Mikes doesn't have enough grip yet to be running stiff setups like that.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 04-22-2004, 12:46 PM   #10146
sorry:
Front:
Toe: 0
Droop: 3mm
Pivot: 0F
Pulley: Standard
Ride Height: 4mm
Arm Spacing: fwd
Front Drive: diff
Shock tower: 2 top/ 2 lower
Rollcenter: low
Carrier: 4deg
Ackerman: back
sway bar: .080
camber ball stud: chrome
Shocks:
50wt
56
yellow
Rear:
toe in: 2
Droop: 3mm
Camber Stud: chrome
pivot: 0R
Ride Height: 4mm
Arm Spacing: back
rear carrier ball stud: inner hole(A)
arm: inner/offset
shock tower: 3top/ 5 lower
Rollcenter: low(MF)
shocks:
50wt
56
orange
I think that's it..
Old 04-22-2004, 12:47 PM   #10147
I will be trying your suggestion tomorrow.. I was able to get the springs & pistons so I am good to go..
Old 04-22-2004, 12:53 PM   #10148
The Evicerator
If the track doesn't have alot of grip I'd recommend just softening up your springs... I've run as soft as losi black in the front and losi purple in the rear....
You might not need to go that soft...but just keep it in mind!
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 04-22-2004, 12:56 PM   #10149
David suggested black all around... will try that and I may try white springs as well..
Old 04-22-2004, 12:58 PM   #10150
I liked the black springs all the way around. I didn't a chance to try purple in the rear. One thing I've learned about this car on carpet. It wants to be pushed real hard. It can handle it no doubt.
Old 04-22-2004, 12:59 PM   #10151
I tried white the first time I was there. Still think it was a little to stiff. With them just changing the layout not to long ago I'd say stick with the black.
Old 04-22-2004, 01:03 PM   #10152
And the track will change it 4 weeks again... right in the middle of the series we are having...
I will try the black springs the next time out..
Old 04-22-2004, 01:08 PM   #10153
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Its pretty easy, just gotta have a steady hand. I'll be doing 2 more chassis' next week.
Old 04-22-2004, 01:23 PM   #10154
RandyB's Avatar
what bits sre you using??
Old 04-22-2004, 01:30 PM   #10155
I got the kit today. Reading through the distructions, err instructions as I type. Should have most of the car done by Monday or Tuesday.
wcoyote is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
