Old 04-22-2004, 10:50 AM   #10126
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Originally posted by jkerr0043
Unless you've got some real drive train binding, lack of acceleration is more than likely going to be a motor,battery,ESC, or even radio issue. I've seen guys get frustrated that they don't have speed and after looking at the radio settings, they'll have a throttle endpoint or something like that set wrong. You may have the ESC setup wrong. You never know.
Yep, my guess would be motor/battery. Hard to get two motors the same, so its hard to judge just by changing cars.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 04-22-2004, 10:55 AM   #10127
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 3 (80%+)
Send a message via MSN to clinttredway
I also have new batteries coming and I am going to play with my motors.. car setup and go through my radio as well..
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 04-22-2004, 11:04 AM   #10128
imjonah's Avatar
Default ID foam tires
If you forget to mark TRC foam tires is there any way of ID ing them telling pink from plaid from purple on dish wheels?
imjonah is offline   Reply With Quote
Old 04-22-2004, 11:13 AM   #10129
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Does the MF Hop ups come in other colors?
I know you all dig the red but I more a blue guy.
Speedtech has stuff in silver, but i was just wondering if there were other colors?
JohnMatrix is offline   Reply With Quote
Old 04-22-2004, 11:19 AM   #10130
Just the signature MF RED .
James Nguyen is offline   Reply With Quote
Old 04-22-2004, 11:21 AM   #10131
RandyB's Avatar
by feel if you or sombody you know has another set that you know are marked compare the firmness etc.
pink softer than purple plaid have a outer ring
RandyB is offline   Reply With Quote
Old 04-22-2004, 11:27 AM   #10132
you could use a tire durometer.
Old 04-22-2004, 11:37 AM   #10133
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by RandyB
Randy yours looks sweet just milled a little but not cut through wish I could do that but i would need a mill
I did it with a dremel.
Old 04-22-2004, 11:39 AM   #10134
Originally posted by clinttredway
I just drove a friends XRay and we have very similar electronics setup and without much practice, I went consistently 1 sec faster with his car than with mine... That's why I am going to go through everything on my car...
If you can go 1 sec faster with his car then there is something seriously wrong with yours, weather it be drivetrain bind or setup, you gotta figure it out..
Old 04-22-2004, 11:47 AM   #10135
that's what I thought as well.. I know the suspension is free.. as far as the drive train.. I don't have a 'free drivetrain' xxx-s to compare to.. but I will be going through it starting tonight to figure out if there is something wrong and where it is...
his setup is also more aggressive than mine and that could be as well.. if I make my car softer, will it be more aggressive or ?
Old 04-22-2004, 11:54 AM   #10136
Just saw on the Losi site. MF2 XXX-T. Can we say Kinwald BK2 for truck?
Randy The panther was cool. I think he was called Ravage.
Back to TC....Do the low roll center blocks seem to be one of the most valuable aftermarket tuning components? Basically are most of you guys using them? I'm essentially making a list of what things should be high on the list for this cars tunability. I figure on down the road after I drive the kit box stock, I'll have to try out a spool setup and some other things. Just to see what works best. I'm just trying to get a jump on some of it if I can.
wcoyote is offline   Reply With Quote
Old 04-22-2004, 11:55 AM   #10137
With the wheels on the car and your motor unattached, you should be able to get 3-4 secs of free spin.
If you stiffen your springs up the car will react faster and become more twitchy, also roll less. This is good for smooth tracks. For bumpy tracks run softer springs and possibly swaybars to reduce the roll.
Old 04-22-2004, 12:00 PM   #10138
Here is what I am running ATM:
front:
new yellow springs 56 50wt
.080 sway bar
plaid TRC 59mm
rear:
new orange springs 56 50wt
no sway bar
purple TRC 59mm
the car doesn't really rotate at all either, in fact today its pushing
Old 04-22-2004, 12:02 PM   #10139
you can do a bunch to make it more aggressive. lighter shock oils will let the car transition faster. stiffer front spring will make it more aggressive. so will less caster. shorter front camber link. more stood up front shock. less front droop. a ton of stuff. all depends on your setup now. go to the track one full day and mess around with each adjustment one at a time so you can get a feel for what each does.
Old 04-22-2004, 12:02 PM   #10140
I should say that I will be try a slightly softer setup very very soon
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
