Old 04-20-2004, 11:05 AM   #10051
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Hey Randy,
If I were to do the same thing with 90 tooth spur,
what would you recommend?
And also, should I cahnge from the 90tooth? whats the disavantages of it?
Thanks Nick
JohnMatrix is offline   Reply With Quote
Old 04-20-2004, 11:16 AM   #10052
NVisible's Avatar
Default belt noise
anyone notice that the black belt system makes more noise than say.. the stock one? I recently changed over and i seem to be getting a high pitched sound at higher speeds.
i say belt because its the only thing i changed, could it be somthing else? my gear mesh is the same as before
NVisible is offline   Reply With Quote
Old 04-20-2004, 11:39 AM   #10053
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by JohnMatrix
Hey Randy,
Thanks Nick
I honestly havent touched a 48 pitch gear on a sedan in almost a year now, 64 pitch is much better for fine tuning. Just try to get the same final drive ratio with your 90 tooth gear as I got with the 128/30.
Old 04-20-2004, 11:40 AM   #10054
Default Re: belt noise
My car is very quiet with the black belt, and I havent used any grease or anything. Check to make sure it's not too loose and rubbing on the tunnel too much.
Old 04-20-2004, 12:06 PM   #10055
NVisible's Avatar
yup, was just a little too loose. thanks!
Old 04-20-2004, 12:10 PM   #10056
mwcet8k's Avatar
Default Digital Servo
What do you guys think is a good digital servo for TC racing? Anyone know which Airtronics servo the team drivers use?
mwcet8k is offline   Reply With Quote
Old 04-20-2004, 12:25 PM   #10057
Default Re: Digital Servo
Either the 94357 or the 94452. 357 is faster but the 452 is slightly slower and easier to drive with.
James Nguyen is offline   Reply With Quote
Old 04-20-2004, 12:26 PM   #10058
mainracer's Avatar
Send a message via AIM to mainracer
I think they use 94452 but not sure
I use a 94758 and I like it I also had a 94357 and it was also good !!
Keven Hebert
AE / Reedy / LRP
KOpropo / Much-More / Parma PSE / Protoform / APS ceramic Bearing / BawdyShop / Fastcats / Dekelz
mainracer is offline   Reply With Quote
Old 04-20-2004, 12:33 PM   #10059
A lot of the mod guys are using the 452 now but for some odd reason airtronics just discontinued it.
Old 04-20-2004, 01:32 PM   #10060
I like the 357 personally, if it's too fast, just turn the speed down on the radio. I generally like the car a bit on the twitchy side though.
Old 04-20-2004, 03:07 PM   #10061
For the budget racer i'd use the hitec hs-5925mg. It's fast, strong, digital, and about 79.99 @ lhs. I'd like to start using the KO Propo pds-2343 but I don't have that in the budget yet.
Poppa Ray is offline   Reply With Quote
Old 04-20-2004, 04:10 PM   #10062
I've had a lot of problems with Hitec in the past, in fact one of their servos stopped working conveniently at full throttle on my 1/8 scale buggy on the straight. This is after I bought a Lynx 3D that wouldn't even transmit a signal. I wont use them for anything anymore, and for just $30 more than that $80 price you can get the 357 and propably never see a problem.
Old 04-20-2004, 04:19 PM   #10063
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I've got the same 357 in one of my cars that I got 2 years ago and it works great. I run them in all my cars.
Jon Kerr is offline   Reply With Quote
Old 04-20-2004, 05:39 PM   #10064
Send a message via AIM to Kave
i used the 357 in my xxxs, then my tc3, now my b4 and xxx4, and its soon to be the stearing servo in my 1/8th scale, i love them, and like randy i like a twitchy car, alows me to throw it thru bad situations more
Kave is offline   Reply With Quote
Old 04-20-2004, 05:44 PM   #10065
woozer71's Avatar
Trader Rating: 23 (96%+)
Can someone please tell me the weight difference between the graphite + and the plastic chassis, with everthing except electrics in it? My car(plastic) weighs 1589 grams with everything in it.
woozer71 is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
