Old 04-20-2004, 07:54 AM   #10036
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
The carpet just doesn't have enough bite yet to be running stiff setups like that. Cyan/Magenta are a softer tire and I thought they really gave me the grip I wanted to push it harder. Carried a lot of corner speed.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 04-20-2004, 07:58 AM   #10037
mwcet8k's Avatar
Originally posted by DavidAlford
Thats your problem. Ditch that motor. Its got no punch at all. Get you a good monster stock and start about 31/128. Run is a few mins and check the heat. If its too hot the go down a tooth. That quad mag stock is just....whats a nice word....slow.
So you think it's a good idea to run a lower ratio with the monster stock? I've always heard that you typically want to run a slightly higher ratio with that motor compared to other stocks.
mwcet8k is offline   Reply With Quote
Old 04-20-2004, 07:59 AM   #10038
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 4 (83%+)
Send a message via MSN to clinttredway
Ok. I got this car from one of the other racers and this was his setup. I like it, but I am willing to try other options.
I will change my car to this setup and do some testing...
Thanks David.. I really appreciate the advice.
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 04-20-2004, 08:00 AM   #10039
No Problem, its what I'm here for.
Old 04-20-2004, 08:05 AM   #10040
I've always kept my monster stocks around 30-33 on the pinion just depending on the track. Its gonna get hot cause its a stock motor. Just don't let it get unsolder the brushes hot lol I guess a lot of it could depend on your motor setup too. I've always stuck with 4499s and red/green. I don't run stock enough to try lots of different things. I'm sure one of the other guys could give you tons more info then I could. Thats just what works for me.
Old 04-20-2004, 08:09 AM   #10041
mwcet8k's Avatar
By the way, are you running the new kevlar spur? If so, what do you think about it? I'm running 48P gears right now, but I really like my cars to run as quietly as possible, so I'm thinking about switching to 64P. What type of pinions do you use?
Old 04-20-2004, 08:14 AM   #10042
I am running the non-kevlar 128 64 pitch with Robinson pinions and its quiet as can be...
Old 04-20-2004, 08:20 AM   #10043
mwcet8k's Avatar
Which Robinson pinions? Purple or black?
Old 04-20-2004, 08:20 AM   #10044
Black
Old 04-20-2004, 08:54 AM   #10045
Kevlar is going to be tough to strip, but louder. It's also heavier then the stock blue spur.
Old 04-20-2004, 09:26 AM   #10046
EddieO's Avatar
When it comes to the spur gears.....I can tell you about half of the team guys were using the blue one and the other half were using the kevlar. Those using the kevlar had drilled it out to lighten it up. They didn't seem really any louder to me, though I did spot one driver putting some of that pink aero lube on his spur/pinion. His car was ultra quiet....
There were a few drivers using a plastic gear adapter and using aftermarket spurs.....Kinwald had this setup.
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 04-20-2004, 10:32 AM   #10047
pro3racer's Avatar
i find my kevlar to be louder than the blue gear, i run robinson pinions too.
pro3racer is offline   Reply With Quote
Old 04-20-2004, 10:34 AM   #10048
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I've had good luck with the Binary 2 motors once I learned how to tune and gear them. Try Trinity purple springs, Reedy 767 brushes, and gear it 30/128, should be a good setup, mine has only been faster than the monsters..
Old 04-20-2004, 10:49 AM   #10049
running mine @ 27/128 it was getting HOT! I can't imagine going up another 2 teeth...
Old 04-20-2004, 10:58 AM   #10050
It's 3 teeth
But it's fast... The worst that can happen is you'll cook some brushes.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
