Old 04-17-2004, 09:03 AM   #9991
pro3racer's Avatar
i think you shouldn't, because the difference made is near nothing, because this belt is so smooth anyway. there was a big difference in the yellow/blue belt, but with the black belt, just leave it.
pro3racer is offline   Reply With Quote
Old 04-17-2004, 09:34 AM   #9992
Randy Caster's Avatar
Trader Rating: 45 (100%+)
I'll know here in a couple weeks, going to throw a new HD belt on my car, I'll see if I can run it loose enough to where it's more free than cutting teeth...
Old 04-17-2004, 02:13 PM   #9993
Cardboard's Avatar
Send a message via AIM to Cardboard
Default ackerman
hey
how do you do the matt francis ackerman setup? do you just drill a 3/16 hole in the exact middle of the connecting tie-rod between bellcranks and put the ball stud in the servo horn in the other way(ballstud points towards the back of the car)?
what are the advantages of doing this?
also, how do you flip the ackerman like it says on the G+ setup sheets? i don't have a g+ chassis, can i still make this adjustment? what difference does it make?
Cardboard is offline   Reply With Quote
Old 04-17-2004, 02:40 PM   #9994
Still Bill's Avatar
Default Re: ackerman
Originally posted by Cardboard
hey
MF's setup really isn't a change in the Ackerman setup. His thing extends the length of the turnbuckle from the near side of the draglink to its far side.
First, you completely remove the standard Ball Stud on the Draglink. Second, replace the screw (that attaches the far side of the Draglink to the Bellcrank on the battery side of the car) with a ball stud that has the same thread length. Third, make a longer turnbuckle (about 2") to replace the original unit (about 1").
Doing this mod makes it so the turnbuckle from the servo to the draglink doesn't go through such radical angular changes. Matt showed me this mod several months ago and I use it on both my cars. Wouldn't change back!
The Ackerman change thing deals with using the forward mounting post position in the G+ chassis and exchanging the arms from left to right (and flipping them). See the Hodgimoto site for previous postings about this setup.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 04-17-2004, 03:11 PM   #9995
akrcracer's Avatar
I would stay away from al. outdrive made by anyone. I had some niftech ones. They didn't last long. Even though cvd bones have nice swivel pins, which made bone fit in outdrive well. Swivel pins made notch in outdrive after 4 months of racing.
akrcracer is offline   Reply With Quote
Old 04-17-2004, 04:43 PM   #9996
Xtant3150c's Avatar
Originally posted by James Nguyen
SPEEDWORLD or call 916.783.8864. They are in California.
Thanks James for the info and link!
I guess I need to try and check with some lhs to see if they can get parts? Shipping is still $17 for a $7.50 pulley's?
Xtant3150c is offline   Reply With Quote
Old 04-18-2004, 01:33 AM   #9997
JayBee's Avatar
Trader Rating: 31 (100%+)
Default Smoking ESC
I just realized that my 19T motors' endbell on this car doesn't come off the can (so I broke it off--accident by experimentation). Oh well, that just gives me an excuse to go buy a new motor & that's just what I did. The paperwork that came with the car mentioned about not using a motor w/ less than 15T's (it ruins the esc). So I went out and bought Trinity's Speed Gems Pro 15TDB motor. I put it in, ran the car for alittle while but took the car inside when it started to act up. Tried running it some more and that's when I noticed smoke billowing out from the esc. Did I do something wrong here (maybe like buying a 15TDB mod motor)?
And will getting GM Racings' V4r or V6r esc fix my problem?
Thanx 4 the help N advance
JayBee is offline   Reply With Quote
Old 04-18-2004, 02:35 PM   #9998
HK Racing Joe's Avatar
Send a message via AIM to HK Racing Joe
well the limit is 15 that means it COULD run it but you should run atleast one turn over the limit
HK Racing Joe is offline   Reply With Quote
Old 04-18-2004, 05:17 PM   #9999
pro3racer's Avatar
Default lol
has anyone tried putting a 8 turn on a msc, something to do when your bored and you spy a msc sitting the corner collecting dust. I've done it, it sure works good for about, oh, 2 full speed runs.
Old 04-18-2004, 05:55 PM   #10000
Still Bill's Avatar
Default Todd Hodge's Birthday Today
Hey,
Todd Hodge is 30 today. Please go to the "Ask Hodgimoto" string and leave him some Happy Birthday wishes. Thanks.
Old 04-18-2004, 06:11 PM   #10001
Brandon R's Avatar
10,000th post....man what a thread and a car!!
Brandon R is offline   Reply With Quote
Old 04-18-2004, 06:23 PM   #10002
Still Bill's Avatar
And I gotta think that Randman has about 3,000 of them on this thread.
That Randy is one helpful/interesting/thoughtful contributor. And he is nearing 10,000 posts.
Old 04-18-2004, 08:17 PM   #10003
JayBee's Avatar
Default SMOKED ESC
If it's not too much trouble, can SOMEONE answer my thread?
Old 04-18-2004, 08:28 PM   #10004
mwcet8k's Avatar
Default Re: SMOKED ESC
Give us some more specifics, like what model speed control you were using. If you had your car over geared, that combined with the fact that you were using a motor that was right at the limit of your ESC may have been enough to fry it. Was your motor really hot at the end of each run to the point that you couldn't hold your finger on it for more than a second or two? That's a sure sign that you were over geared.
On the other hand, it could just be a bad/cheap ESC.
mwcet8k is offline   Reply With Quote
Old 04-18-2004, 08:29 PM   #10005
gearing is off maybe or the timing might be too high? gear mesh might be too tight causing high load. speedo got too hot, too much load on it, speedo starts smoking.
James Nguyen is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
