Old 04-12-2004, 12:21 AM   #9871
EddieO's Avatar
R/C Tech Charter Subscriber
Assuming those are either Jaco or TRC foams....thats a pretty weird tire stagger. Either go cyan/magenta or plaid/purple (thats front/rear)
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 04-12-2004, 06:51 AM   #9872
Still Bill's Avatar
Thumbs up
futureal,
Nice post! Pretty neat when you don't have to talk "business".
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 04-12-2004, 10:19 AM   #9873
John_S's Avatar
also cardboard try running 5mm ride height on the front aswell this should balance out the weight transfer a bit more
John_S is offline   Reply With Quote
Old 04-12-2004, 10:46 AM   #9874
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I'd definately say that the 2 degrees front toe in is 90% of what's causing the understeer...
Old 04-12-2004, 11:31 AM   #9875
rcracer0229's Avatar
Send a message via AIM to rcracer0229 Send a message via MSN to rcracer0229
yea that should work
rcracer0229 is offline   Reply With Quote
Old 04-12-2004, 06:05 PM   #9876
Just learned I made it into Reedy, time to build up a new XXXS
Old 04-12-2004, 06:20 PM   #9877
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Randy, empty your inbox
Jon Kerr is offline   Reply With Quote
Old 04-12-2004, 06:40 PM   #9878
NVisible's Avatar
just to fire an off the wall question out there.
i seem to be having a problem keeping my car straight. i seem to have everything lined up in my steering right, but after a while my car seems to drift left or right. I can adjust on the fly with my radio, but eventually it starts drifting again to either direction.
Could it be my RTR servo? Servo saver? Pretty annoying to have to be adjusting my car mid race
NVisible is offline   Reply With Quote
Old 04-12-2004, 06:46 PM   #9879
Servo saver, try using an extra silver ring on it, or just get rid of it if you drive clean.
James Nguyen is offline   Reply With Quote
Old 04-12-2004, 07:49 PM   #9880
POOKYT's Avatar
Sounds like the servo. Most RTR's do not have a high quality servo. You pay big money for a good servo but you not only get speed or torque but they center better than stock servos. Hope this helps
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 04-12-2004, 09:09 PM   #9881
Cardboard's Avatar
Send a message via AIM to Cardboard
ok, i'll pick up the hudy sticker and check that first.
thanks for the help futureal and randman.
Cardboard is offline   Reply With Quote
Old 04-12-2004, 09:19 PM   #9882
Still Bill's Avatar
Default Ceramic diff balls
Randy,
Good luck with the Reedy. If you can, please post pictures of the new baby (eh, car).
Have you ever used ceramic balls in the diffs? Pretty much decided to upgrade to ceramic bearings; but, not sure if the diff balls will be worthwhile. Any advise is appreciated.
Old 04-12-2004, 09:20 PM   #9883
Done..
Old 04-12-2004, 09:21 PM   #9884
Just get a regular ruler and measure the distance between the inner front and rear of your front rims, get it equal, or shorter in the rear of the rim.
Old 04-12-2004, 09:23 PM   #9885
Default Re: Ceramic diff balls
Originally posted by XXX-S Bill
Randy,
I'll post pics, but I'm not gonna rush the car, want to get this one perfect... I'll do a bit nicer job on the new chassis too, it'll have some design element to it
Ceramic diff balls are awesome, they last forever, but they do lighten the rotating mass which is awesome for carpet and high bite surfaces, but isn't what you want for low traction surfaces. I'll actually propably run weights on my spur gear at Reedy as well as steel outdrives.
James - I've thought of more stuff I need to order, please send me an IM when you get back.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
