Old 04-10-2004, 02:39 PM   #9811
Cardboard's Avatar
Send a message via AIM to Cardboard
hey
went back to the track today. car is really getting there. seems like it only needs a few more changes 'till it's dialed.
i'm having 2 problems:
1)slight understeer, can't turn sharp enough for some turns, despite my servo atv being set at 80%.
2)still having problems with rear grip. nothing too serious, but i have to fight the car to prevent powerslides after hard turns.
here's my setup, i'm racing on a pretty tight carpet track.
2 degrees of toe-in
4mm ride height
2 degree hub carriers
2mm droop
pivot support 4
1 washer under bellcrank ball stud
upper shock mounting hole:2
Camber link mounting hole:2
losi low roll
shocks: 60 wt oil, 56 piston, purple spring
-1 camber
24 mm dbl pinks
rear:
2 degree toe in
5mm ride height
-1 camber
4mm droop
pivot support 0
camber link in hub: location A
camber link in tower:hole 1
upper shock mounting location:hole 2
lower shock mounting locationutside
losi low roll center
shocks: 80 wt oil, 55 piston, purple spring
26mm purples
battery placed rearward
Cardboard is offline   Reply With Quote
Old 04-10-2004, 04:07 PM   #9812
Default Pictures of our cars
Here is the front of my car
Losi Lunatic is offline   Reply With Quote
Old 04-10-2004, 04:08 PM   #9813
A picture of the back
Old 04-10-2004, 04:10 PM   #9814
A picture from the top
Old 04-10-2004, 04:13 PM   #9815
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: Re: Re: gear ratio?
Originally posted by rice
forgot to mentioned im using a 48pitch gear. i'm using a 90 or 88 spur. can u give me the final drive ratio?
Sorry, dont know the final drives... Just calculate them with the internal ratio for final drive.
Old 04-10-2004, 04:13 PM   #9816
pro3racer's Avatar
cardboard, try a looser rear spring, i believe the black spring(losi) is softer, or try the silver, if that doesn't solve the rear looseness, lay the shocks down on hole on the top.
pro3racer is offline   Reply With Quote
Old 04-10-2004, 04:18 PM   #9817
Cardboard, I agree - try silver spring (softer than Purple I think). May also want to try 1.5 - 2.0 on rear camber. Everytime I change camber it seems to make a big difference
Old 04-10-2004, 04:46 PM   #9818
mainracer's Avatar
Send a message via AIM to mainracer
Default my car
here is my car :
Keven Hebert
AE / Reedy / LRP
KOpropo / Much-More / Parma PSE / Protoform / APS ceramic Bearing / BawdyShop / Fastcats / Dekelz
mainracer is offline   Reply With Quote
Old 04-10-2004, 04:47 PM   #9819
mainracer's Avatar
Default my car
a second shot :
Keven Hebert
AE / Reedy / LRP
Old 04-10-2004, 06:31 PM   #9820
Cardboard's Avatar
that was a typo, i was running the stock silver springs.....sorry for the mixup.......
i do have the orange and white rear springs, will switching to those help?
Old 04-10-2004, 06:53 PM   #9821
Default Re: my car
Originally posted by mainracer
a second shot :
Cool gear cover... might have to have my painter do something like that with my colors..
Old 04-10-2004, 07:02 PM   #9822
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Nothing special on my car. Some blue stuff and a fairly clean layout. BTW, I like your painted gear cover.
Jon Kerr is offline   Reply With Quote
Old 04-10-2004, 08:03 PM   #9823
Korey Harbke's Avatar
Yeah, the gear cover is trick.
-Sushi Boy
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-10-2004, 08:29 PM   #9824
pro3racer's Avatar
Cardboard, i really don't want to have to rummage to my spring collection, but heres my saying, if your rear end is loose, go to the softest spring(common sense though), and go up from there.
Old 04-10-2004, 08:40 PM   #9825
Rather than going to the softest spring, it will be better to go down 1 spring. Going to the softest is going to hurt more than help in most cases.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
