Losi XXX-S
#9766
R/C Tech Elite Member
The BK bones are cool, but just like Matt Francis told me, they are just like running a new outdrive.
The black belt is worth the cash, but I am already experiencing skipping with it if it isn't tight. That is with every other tooth cut off though, so the standard belt may not have that problem.
#9767
Originally posted by lazyboy
any word on those bk bones yet??
#9768
k thanks guys for replying so quick,
lazy
lazy
#9769
Originally posted by Randman
About 1 in 10 aren't loud, so you got a lucky one. The blue gears are all quiet though, so I'll stick with them.
Actually, mine is moderately noisy; but, I see (hear) your point about listening to the motor whine...Sweet!
#9770
Originally posted by James Nguyen
Exactly what Randy said, I think they only make my outdrives last a few more runs before they start digging into them again. As long as you keep the gouges(sp?) off of the outdrives by filing them flat each run the regular losi bones should be fine. They are just another bling part on the car that adds more bling than performance.
#9771
I think matts bones are wear a tad bit also. ??? dunno, maybe i need to machine the bearings in on the pin more. i've only ran one set so far, but maybe its just me seeing things.
#9773
ok, i think its just my tolerances on the outdrive itself. I'll machine the outdrive tighter and file it to fit perfectly.
#9775
gear ratio?
question?
i have a xxx's losi planning it to run mod. motors. i have a d5 8x1 what's the best ratio i'm a gonna used?
our local track the lay out is more on technical and combination of high speed. the straight is about close to 50 meters.
#9776
Originally posted by brians11
does anyone know of a place (online or local hobbyshop) that has the new belt kit in for the sedan? tryin to find one....
I have been looking for weeks.
I don't know of any it's like trying to hit the lottery.
does anyone have any info on where to get one?
#9777
are u guys talking about the new black belt cause my lhs has em
#9778
Re: gear ratio?
Originally posted by rice
question?
question?
