Old 04-04-2004, 08:20 PM   #9706
Default Re: Turnbuckles
Originally posted by NVisible
I really dislike adjusting my turnbuckles on my xxx-s. Seems when i try to adjust they always pop out, or i have to use needle nose pliers on one end as i try to adjust them, just a pain in the arse. Im using the ones that came with the RTR kit, would a lunsford set with the rpm ends help this at all? maybe im doing something wrong. I even put lube on them like it said in Drakes article in RC Nitro, but same thing
I had the same problem with my RTR - the ball ends are very hard. Use the Lunsford turnbuckles (or titanium turnbuckles from graphite kit) with the RPM rod ends (I used the short rod ends) I then turned the turnbuckle into and out of the rod end 5 times to establish a clean thread. They work great. They never slip and I can adjust them without popping off.
Losi Lunatic is offline   Reply With Quote
Old 04-04-2004, 08:24 PM   #9707
Default Stripped Threads on chassis
Does anyone know how to fix stripped theads on the graphite chassis. I have stripped 2 of the 3 screws on the gear cover and 1 screw on the front diff cover.
Old 04-04-2004, 09:04 PM   #9708
Cardboard's Avatar
Send a message via AIM to Cardboard
you can either rethread using ca glue or get longer bottom cover screws. i'll try to find the exact screw measurements you'll need.
Cardboard is offline   Reply With Quote
Old 04-04-2004, 09:08 PM   #9709
Thank you. I will try the CA glue
Old 04-04-2004, 09:08 PM   #9710
Cardboard's Avatar
2-56x1/4"
Old 04-04-2004, 09:28 PM   #9711
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Originally posted by xxxkat
On removing every other tooth on the belt are you doing this on the black belt also ? And how is this belt "trick" holding up in mod,I run a 10x2 most of the time and dont really like changing belts..
I'd consider a 10x2 a rather mild modified... I dont have any problems with the belt skipping with low turn mods and I run the belt really loose.
Old 04-04-2004, 10:24 PM   #9712
Cardboard's Avatar
what changes should i make on todd hodge's snowbird's setup for a tight track? i was thinking normal wheelbase and less front caster.
Are the ae hexes really worth it? my hexes always seem to come out with the wheel, so they must be worn, but the price on the ae hexes .
on a side note, i'm really bummed that my local track is closing for the summer. i only got to go there 5 times . now my xxx-s has to go into storage after next weekend .
Old 04-04-2004, 10:47 PM   #9713
Still Bill's Avatar
Talking
Originally posted by racer-oZ
XXX-S Bill, how long have you been waxing your turbuckle? couldn't resist that one!
racer-oZ
Resist...Resist...
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 04-05-2004, 02:29 AM   #9714
Originally posted by Cardboard
how many degrees of anti-dive do the low-roll pivot blocks add?
Using a 0F front block in the lower diff case holes and losi low inner pivots it should give you 2 degrees of anti-dive.
James Nguyen is offline   Reply With Quote
Old 04-05-2004, 09:25 AM   #9715
I picked up the carbon AE hexes, only a couple bucks and they worked fine...
Old 04-05-2004, 02:27 PM   #9716
EricF's Avatar
...Are the ae hexes really worth it? ...
I thought that the use of AE hexes are to set the track to its maxium beacsue the TRC wheels have a different offset which makes the car less than 190mm.
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 04-05-2004, 02:29 PM   #9717
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 3 (80%+)
Send a message via MSN to clinttredway
sometimes when you use 28mm tires they rub and the AE hexes are a bit thicker which is enough to help with the rubbing..
clint
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 04-05-2004, 04:51 PM   #9718
Oasis's Avatar
Trader Rating: 36 (100%+)
10 winds are what most of the guy's run at the track I race at,it's not that big of a track.
Oasis is offline   Reply With Quote
Old 04-05-2004, 05:19 PM   #9719
the use of the ae hexes or other aftermarket hexes were not so much used for clearance with rubbing as they were to compensate for the offset on the older style trc wheels to get the regular track width. the new trc 28mm wheels have the regular offset so you can use the stock hexes.
Jarrod Langlois is offline   Reply With Quote
Old 04-05-2004, 06:15 PM   #9720
hehe, SoCal isn't too big either, and we use down to 6t
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
