Old 10-31-2001, 12:12 AM   #946
Thanks for the help futureal... I have not had a chance to do anything with it yet. But will tomorrow.
PS Like the new smilies... lol
Boxcar is offline   Reply With Quote
Old 10-31-2001, 05:57 AM   #947
Rocket Ronbo's Avatar
Send a message via AIM to Rocket Ronbo
futureal....
What did you lube the one-way with? There are a couple products out there for one-way bearings but never use a standard bearing lube!!!!!!! The one-way has to lock up so standard lube is not good.
Now to address the breaking problem... you have to run the saver ring (small alum. ring) on the outdrive cup. If you had the ring on not sure how you broke it (man... even I haven't broke one of those yet and I break everything, it's my job of course) ask Mark.
Well thats all I know
Ron Rossetti
Addict
About my set-up on the Lost Web site, try it both ways (with and without under-drive) yes the springs are correct.
Rocket Ronbo is offline   Reply With Quote
Old 10-31-2001, 06:26 AM   #948
Manticore's Avatar
R/C Tech Charter Subscriber
Originally posted by Rocket Ronbo
futureal....
Ron Rossetti
Addict
use the serpent one-way lube !
Manticore is offline   Reply With Quote
Old 10-31-2001, 06:57 AM   #949
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
ron...you setup rocks for pavement....i ran it and loved it....
i also use the serpent lube...
Matt M. is offline   Reply With Quote
Old 10-31-2001, 08:32 AM   #950
Trader Rating: 19 (100%+)
futureal....
Ron Rossetti
Addict
Ron,
You left yourself so wide-open after that breaking comment, but I'll hold back this time.
MDawson is offline   Reply With Quote
Old 10-31-2001, 08:38 AM   #951
HarshGuy's Avatar
Speaking of that aluminum ring, I lost one ...I had applied a dab of show goe to them ...and to the base of the little spring hoping that would hold them in case the outdrive "ejected" ...but I didn't think about if the front arm got torn out in a violent crash caused by a big mouth racer hacking the ever living snot out of me, that the dogbone would pull out of the outdrive and take the ring with it ....anyone know if just the aluminum ring is available? I see that it's in the outdrive "kit" but $8.00 for the bag seems like a lot when I'm just after the ring!
HarshGuy is offline   Reply With Quote
Old 10-31-2001, 10:11 AM   #952
R/C Tech Founder
Ron: Sorry, should have been more specific. Yes the lube was one-way lube, though I don't recall who makes it. Got it at my LHS long, long ago and used it in the one-ways in my Yokomo for over a year.
The aluminum retaining ring was indeed on the outdrive. Unless it came off somehow before the breakage, though I don't think so, it was around the driveshaft afterwards. As far as I can tell it was just a freak accident, I turned into a corner a split second too soon and let the left-front wheel of the car hit the barrier while turned inwards, and the thing broke. All I can figure is that with one-way stopping the wheel so abruptly as it hit the barrier, the torque must have all been applied to the outdrive cup.
Glad I was able to break something that the Losi testers couldn't. I win! haha
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 10-31-2001, 10:28 AM   #953
Fortunately the outdrives are cheaper to replace.
I remember breaking oneways on a Yokomo that couldnt be repaired due to the oneway bearings pressed-fitted into the oneway assembly. Once the oneway bearing went out, the whole unit needed to be replaced. $50.00 a shot. I think I have a graveyard of 4 of those.
The Losi oneway is nice because it is modular throughout the outdrives, assembly (left and right side bearing hubs).
Old 10-31-2001, 11:07 AM   #954
R/C Tech Founder
Yea, I went through a couple of Yokomo one-ways too. The outdrive cups never broke since they were made of some sort of alloy, but yea, the thing was all fancy blue aluminum with the one-way bearings built in. Some people sent them back to Yokomo and occasionally got new ones, but if you weren't lucky it was another $50 out-of-pocket.
Old 10-31-2001, 11:10 AM   #955
HarshGuy's Avatar
Oh no doubt I like their setup, it's "one better" that Schumachers, with shumaccher the outdrive was seperate from the main oneway, but the oneway bearing was in the outdrive so it was $15.00 per pop when you smoked an outdrive ...I just want an aluminum ring
Old 10-31-2001, 11:13 AM   #956
I just shaved down a extra set of out drive savers (aluminum) and attached those to the outdrive cups.
Old 10-31-2001, 11:27 AM   #957
Rog
Can someone post the part number for the aluminum CVD dog bones. Thanks
Rog is offline   Reply With Quote
Old 10-31-2001, 11:43 AM   #958
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Mark- The graphite Conversion Kit for the XXX-S..... does that include all the rear hubs you can buy and all the Front Carriers that you can buy right now so I will have all the degrees of changes?
Mike Webb
mike_Webb is offline   Reply With Quote
Old 10-31-2001, 11:55 AM   #959
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
Mike-
From what I understand the kit will just have all the stock parts-
The tuning parts will still be separate.
Rog-
I think the PN#'s should be in the FAQ??? Click the red link on one of M.Dawson's posts...
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 10-31-2001, 12:08 PM   #960
Send a message via AIM to WHITESTER
Aluminum CVD's Front or Rear (XXX-S) A-9929
I got the number outta the book.
WHITESTER is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
