Old 03-29-2004, 09:09 AM   #9571
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by clinttredway
I have all the Losi tools...
anyone know the cheapest place to get the conversion kit?
Thanks!
eBay
Old 03-29-2004, 09:18 AM   #9572
Originally posted by EddieO
While a ballstud would work ok, they are just nromal threads, not special cutting threads like you find on a tap or the tapping screw.
Try KThobbies.com .....pretty good prices on losi stuff.
Later EddieO
I've tried a tap in the past and found it left the holes oversized and a bit sloppy. When I applied even a small amount of pressure to the screws, the holes stripped... I just use a steel cap head screw for each hole, throw it away after 1 hole.
Old 03-29-2004, 09:18 AM   #9573
Another great option for thrust bearings is Traxxas they have the same part you will get from McMaster Carr. It sells for $10 and can be had at any good LHS that carries Traxxas. I have used both with great succes.
Chad
ChadK is offline   Reply With Quote
Old 03-29-2004, 09:26 AM   #9574
EddieO's Avatar
R/C Tech Charter Subscriber
I was too lazy to look up the traxxas part number........by the way Chad, my Ruby diff balls didn't work.....they were SUPER smooth, but when we made the diff slip, they cracked. I guess while they are VERY hard, they have POOR sheer properties.....good news is, I have plenty left to make my wife some Jewelry! The new ceramics I have are just as smooth and ROCK hard.
Sounds like a cheap tap.....one thing I have found is that you get what you pay for in tap sets. I paid way to much for mine, but it sizes holes perfect. The good news is you can buy a quality tap in just the size you need.
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 03-29-2004, 09:28 AM   #9575
I dont know about the tap, it was a craftsman titanium nitride coated tap...
Old 03-29-2004, 09:40 AM   #9576
Randman- What kind of screws are you using? Some of the aluminum and less expensive TI screws are not dimensionaly correct (under-sized). That may be the reason for the problems after tapping. I only use Lunsford Ti screws and tap all holes with a Craftsman tap and the screws are still an the over tight side when going in the first couple of times. Another thing some people do incorrectly is run the tap in to far and the tap bottoms out on the hole then strips the hole out, since you have milling experiance I don't think you are doing that.
Chad
Eddie the rubies sounded to good to be true. I will have to get some stuff from you when I rebuild my car for out door next month after the rap up race at RC/Plus the end of Aprill. Yes it will get a new chassis, 2 1/2 years in a long run for a chassis.
Old 03-29-2004, 09:54 AM   #9577
I use a lot of fastener express aluminum screws, I know they are undersized, but I had the problem with the tap a while back when I just used the stock steel screws.
Old 03-29-2004, 10:00 AM   #9578
an important step that sounds like its missing from most peoples advise on using a tap is= be sure to keep the tap square and dont wobble any. And another important step is, tapping fluid or some sort of lub. Even wd-40 works better than nothing.
A wobbling tap will cause the hole to be WAY over sized.
stumper is offline   Reply With Quote
Old 03-29-2004, 10:37 AM   #9579
I didn't use any kind of lube, so that could be the problem, but I didn't wobble any.
Old 03-29-2004, 11:51 AM   #9580
EricF's Avatar
Chad
Great suggestion... would be even better if it came with a part number
E
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 03-29-2004, 12:13 PM   #9581
EddieO's Avatar
Just get the one from mccmaster carr....The few traxxas ones I got had bends in the race with the bearings....not sure if it happened in shipping or what......my guess is its being shipped from the company, to traxxas, then to horizon....then to the LHS....way to many hands on it. Its the same part though....
Your LHS might have it in stock....
Later EddieO
www.teambrood.com
Old 03-29-2004, 12:14 PM   #9582
The Evicerator
Hey all ...back from the Nationals... got my car working VERY well... I'll post my setup here if anyone would like it....
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 03-29-2004, 12:15 PM   #9583
EddieO's Avatar
TRA2729 though if you want it (thats the horizon part number).....
Later EddieO
www.teambrood.com
Old 03-29-2004, 12:22 PM   #9584
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Hook a brother up Steve, I'd like to see your setup.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 03-29-2004, 12:46 PM   #9585
The Evicerator
Front End:
Arms Std Forward
Losi Low RC blocks
0F block in Low RC holes (for approx 2'-3' anti-dive)
6' Castor blocks
low profile ballstud on castor block
Camberlink up and between 2 & 3 on the shock tower
Ackerman Flipped and forward
1' Camber
0' toe in
0.080" Sway Bar
Shock Position #3
Standard 56s w/ 45 wt Losi
0.060" limiting inside the shock
0.180" limiting outside the shock
Trinity Purple Congo Springs
Droop set to 2 on the losi guage from the set screw boss
4.25 mm ride height
Rear End
Arms Back
1' toe in blocks backwards (offset)
1-A Camberlink w/ short ballstud on hub carrier
0.050" sway bar
1' camber
Shock position #3 and outside on the arm
Standard 56's w/ 45 wt losi
0.120" lmiting outside the shock
Trinity Blue Congo springs
Droop set to 6 on the arm under the ouside hingepin hole
4.25 mm ride height
Misc:
Batteries Forward
TRC Marble Fronts 57.5 mm
TRC Magenta Rears 57.5 mm
Parma Alfa Body
Geared 31/128 w/ "monster" handout
I'm sure I must have forgotten something in there... if I think of anything I'll edit it or feel free to ask me your questions.....
Steve Weiss
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
