Old 03-28-2004, 06:08 PM   #9556
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by clinttredway
thanks, I noticed that there are a few for the TC3 and wondered if there were any for the XXX-S...
I got a used car and it needs a new chassis... I guess I will get a losi graphite chassis..
Clint
You can also check for pics of milled chassis' and do your own custom mill job.
Old 03-28-2004, 06:09 PM   #9557
EddieO's Avatar
R/C Tech Charter Subscriber
Just get a 4-40 tap and tap the entire chassis and other parts.....stuff goes pretty easy that way.
You can also use the tapping screw losi sells. Doesn't work as well as a tap does, BUT its still better than trying to thread a screw into raw graphite.
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 03-28-2004, 06:16 PM   #9558
NVisible's Avatar
i just used a spare ball stud. easy to grip and wont strip...
anyway...
NVisible is offline   Reply With Quote
Old 03-28-2004, 06:17 PM   #9559
clinttredway's Avatar
Trader Rating: 4 (83%+)
Send a message via MSN to clinttredway
I have all the Losi tools...
anyone know the cheapest place to get the conversion kit?
Thanks!
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 03-28-2004, 06:21 PM   #9560
EddieO's Avatar
While a ballstud would work ok, they are just nromal threads, not special cutting threads like you find on a tap or the tapping screw.
Try KThobbies.com .....pretty good prices on losi stuff.
Later EddieO
www.teambrood.com
Old 03-28-2004, 06:29 PM   #9561
NVisible's Avatar
yea definatly. a tap would be way better. just in a bind, thats what i did.
hows those titanium parts going btw?
Old 03-28-2004, 06:30 PM   #9562
EddieO's Avatar
Going to a different machine shop, as the shop I went to first wants som crazy price....he is paying WAY to much for his titanium.
Luckily, I live in an area where there are tons of machine shops.....
Later EddieO
www.teambrood.com
Old 03-28-2004, 06:34 PM   #9563
Originally posted by NVisible
get yourself the conversion kit. just beware, the harware the comes with the rtr xxx-s is pretty crappy and strips easily. Also the screws will be alot harder to drive into the new graphite, so a good set of drivers would help alot, i wish i had my set when i first did the change over.
I have an original xxx-s, not a RTR... it has threaded shocks and graphite arms... but the original chassis...
Old 03-28-2004, 06:39 PM   #9564
evaa's Avatar
hello again. i got the matt francis rear hubs for my xxxs, i was wondering if they are the same as the 1 degree hubs? also, i got hold of those schumacher Ti ball studs and was planning on using them on the rear hubs and the front c hubs. anyone have inputs on those modifications i intend to perform?
by the way i just tried the every other tooth thingy on my car's yellow belt, and boy was it great, very llose drive train.
tanx in advance guys.
evaa is offline   Reply With Quote
Old 03-29-2004, 03:34 AM   #9565
NVisible's Avatar
thats cool.
Old 03-29-2004, 05:55 AM   #9566
RichO's Avatar
Does anyone happen to know the part number for the thrust bearing assembly (captured balls in the black harness) that works with the XXX-S?
I had the number the other day but misplaced it and I need to order replacements.
This part works in place the free balls between the washers; instead it has a black harness that has the balls in it.
Thanks in Advance...
RichO is offline   Reply With Quote
Old 03-29-2004, 08:31 AM   #9567
EddieO's Avatar
If you want to use the best, get the one most of the pro's including hodge, francis, kinwald use.....
Here is the McMaster-Carr part # for the thrust bearing.
7806 K53 miniature steel metric ball bearing for 3mm shaft dia, 8mm OD
They cost about $10 bucks, but it will last a LOT longer and perform better.
Later EddieO
www.teambrood.com
Old 03-29-2004, 08:43 AM   #9568
mainracer's Avatar
Send a message via AIM to mainracer
where can I get those thrust bearing??
Keven Hebert
AE / Reedy / LRP
KOpropo / Much-More / Parma PSE / Protoform / APS ceramic Bearing / BawdyShop / Fastcats / Dekelz
mainracer is offline   Reply With Quote
Old 03-29-2004, 08:47 AM   #9569
EddieO's Avatar
Sorry, I suck....forgot the URL
http://www.mcmaster.com
Later EddieO
www.teambrood.com
Old 03-29-2004, 08:52 AM   #9570
RichO's Avatar
No problems. I figured it out. Turns out there is a location here in Atlanta... I just made the order so it should be here this week.
Great advice though!!
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
