Old 03-26-2004, 03:20 PM   #9541
Spanky's Avatar
Reduce your steering throw, if it goes to far, tour cvd's bind and cause vibrations. Its best if youput your car on a stand and give it some power, when you turn , you will see the vibration, reduce the throw and it should stop.
Spanky is offline   Reply With Quote
Old 03-26-2004, 04:31 PM   #9542
BG
BG's Avatar
Default Re: I have a PROBLEM!!!!
Originally posted by SPC Racing
When i trun under power the front wheels shake like a son of a bitch. what can i do to correct this.
What tires are you using? Foam or rubber? If it is rubber what make?
Cheers
Bill
BG is offline   Reply With Quote
Old 03-26-2004, 05:31 PM   #9543
i am running take off 27's
SPC Racing is offline   Reply With Quote
Old 03-26-2004, 05:49 PM   #9544
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
SPC racing....are you having this problem when the car is on the track or just when you are holding the car or when its on a stand? I've had the same problem but once the car was on the ground I never noticed it. Make sure that your wheel nuts are not too tight.....and take a little steering travel out. But you should not see this on the track when the car is at ride height....just when its in the air or on a stand with the wheels off the ground. Hope thi helps
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 03-26-2004, 11:28 PM   #9545
Randy Caster's Avatar
Trader Rating: 45 (100%+)
Make sure your bearings arent blown out as well, the front bearings have a tendency to go pretty easilly.
Old 03-27-2004, 02:22 PM   #9546
Cardboard's Avatar
Send a message via AIM to Cardboard
hey
went to the track today-turns out that is actually was the wheel hub bearings. No more spins for me! This was my first real track day when the car was in great condition-i'm very impressed with it.
i've been having problems with understeer. Any ideas on what may be causing the understeer? I was running an effectively stock setup with 4 degree carriers up front. I think i was running 6 degrees of kickup in the front with no antidive.
How do you prevent chunking foam tires? I rendered a pair pretty much unusable today.
Has anyone noticed a shortage of the TiNi .28 shock shafts? I've been to several hobby stores, they haven't had them, and when i ordered them from one of the LHSs, they have been on backorder for about a month now......
Cardboard is offline   Reply With Quote
Old 03-27-2004, 08:16 PM   #9547
lazyboy's Avatar
Send a message via AIM to lazyboy
try kt hobbies for the shock shafts or stormer they usually have them in stock.
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 03-27-2004, 10:00 PM   #9548
JitsuGuy's Avatar
Send a message via AIM to JitsuGuy
Anyone know where I can see pics of the new Losi prototype TC?
Thanks,
J
JitsuGuy is offline   Reply With Quote
Old 03-28-2004, 08:34 AM   #9549
pro3racer's Avatar
There aren't any! That would help all of us losi guys out by knowing what the car might be. There is a pic of the old prototype in the Spied losi proto. thread New Losi Touring Car Spied
pro3racer is offline   Reply With Quote
Old 03-28-2004, 03:14 PM   #9550
Brandon R's Avatar
any you fellas run a p2k in a xxx-s? what you got it geared for a track that has about a 60 ft straight and a track that has about a 120ft straight? Small one is carpet and other is asphalt.
Brandon R is offline   Reply With Quote
Old 03-28-2004, 05:27 PM   #9551
clinttredway's Avatar
R/C Tech Charter Subscriber
Trader Rating: 3 (80%+)
Send a message via MSN to clinttredway
Is there a good aftermarket chassis for the xxx-s or is the losi graphite the most foavored chassis for this car?
thanks!
Do or Do Not, There Is No Try
clinttredway is offline   Reply With Quote
Old 03-28-2004, 06:52 PM   #9552
thanks!
I dont think there is any aftermarket chassis avalible... no need for one.
Old 03-28-2004, 06:54 PM   #9553
thanks, I noticed that there are a few for the TC3 and wondered if there were any for the XXX-S...
I got a used car and it needs a new chassis... I guess I will get a losi graphite chassis..
Clint
Old 03-28-2004, 06:58 PM   #9554
lazyboy's Avatar
i got the new AE claming hexs and they work so well with foam tires on , i had no rubbing on the shock ends or the front bumper. even tho the fact they were 28 bucks i think it was worth the money.
lazy
Random Guy
FT B4
Trackside hobbies
Old 03-28-2004, 07:03 PM   #9555
NVisible's Avatar
Clint
get yourself the conversion kit. just beware, the harware the comes with the rtr xxx-s is pretty crappy and strips easily. Also the screws will be alot harder to drive into the new graphite, so a good set of drivers would help alot, i wish i had my set when i first did the change over.
NVisible is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
