Old 03-20-2004, 10:06 PM   #9391
Send a message via AIM to ZER01
You measure your total caster by calculating it, if you have 2 degrees of anti-dive(front arms leaning downward 2 degrees) with 6 degree caster blocks then your total caster is 4 degrees. If you have 4 degrees of kickup(front arms kickedup) with say 0 degree caster blocks then your total caster is 4 degrees.
I'm confused on what you mean by main block. If you are talking about the block that captures the hingepins then no, that is not your total caster, that is how much kickup you will be putting on the car but the numbers are differant if you use the losi low roll centers. I beleive if you use the losi low roll centers that the numbers are decreased by 2 when using the bottom holes on the bulkhead.
Cardboard, do you have a G+ kit? Do you know what roll centers are on the car?
ZER01 is offline   Reply With Quote
Old 03-21-2004, 08:29 AM   #9392
Cardboard's Avatar
Send a message via AIM to Cardboard
no, i have the standard kit. The roll centers are stock. By caster block, you mean the pivot block, right? So if i have standard roll centers, then there is no anti-dive? Just kickup from the pivot block?
Cardboard is offline   Reply With Quote
Old 03-21-2004, 08:37 AM   #9393
Randy Caster's Avatar
Trader Rating: 46 (100%+)
The caster blocks are at the end of the arms and the spindles sit in them. I'm sure that even in the standard kit you have 0f 2f and 4f blocks that will allow you to adjust anti dive. I suggest getting some low roll center blocks to get a better variety of tuning options as well.
Old 03-21-2004, 10:16 AM   #9394
Cardboard's Avatar
Thumbs up
ok, thanks all, i think i finally understand it.....
Old 03-21-2004, 10:25 AM   #9395
I recommend getting the XXX Main sedan setup guide, it's really complete and will help you learn to tune your car quick.
Old 03-21-2004, 10:58 AM   #9396
Brandon R's Avatar
I agree with Randman...I never have even looked at a t/c up close untill i got a xxx-s off ebay so I got that book as well and helped out real big...I run gas truck and even helped me out on that too! XXX Main book is really worth the 15 or so bucks it cost
Brandon R is offline   Reply With Quote
Old 03-21-2004, 04:10 PM   #9397
Cardboard's Avatar
can someone give me the exact measurement(length) of a .36 shock body?(entire shock body)
Old 03-21-2004, 04:44 PM   #9398
racer-oZ's Avatar
R/C Tech Charter Subscriber
Default Black Belt
Well, finally got the black belt in at my lhs and got it installed. It does free the drive train up. I am going to wait to cut every other tooth off the belt until I get a backup belt. Can't wait to yank the trigger on this thing! Been way to long waiting for onroad season in Wichita.
racer-oZ
racer-oZ is offline   Reply With Quote
Old 03-21-2004, 05:02 PM   #9399
You wont break the belt any easier when you cut the teeth off, just dont cut into the fibers running through the outside of the belt.
Old 03-21-2004, 05:54 PM   #9400
Brandon R's Avatar
gotta bone stock graphite plus...what kinda hop ups should i get?
Old 03-21-2004, 06:10 PM   #9401
racer-oZ's Avatar
it really doesn't need much for hop ups... front and rear sway bars are good to have... i'd buy some 2 degree and 4 degree hub carriers for the front... and some 1/2 degree rear hub carriers so you can increase or decrease rear toe-in based on track conditions... if you are running on asphault make sure you have full sets front and rear of purple, green, blue and silver springs... if you are on carpet they have 3 springs that are super stiff for carpet.
Hope this helps
racer-oZ
Old 03-21-2004, 06:11 PM   #9402
racer-oZ's Avatar
Here's my ride
Old 03-21-2004, 06:11 PM   #9403
Aluminum screws are cool to drop some weight... I also bought the black belt kit.
Old 03-21-2004, 06:35 PM   #9404
racer-oZ's Avatar
alright, i give, how do you reduce a picture to 80x80 pixels so you can add an avatar to your posts?
racer-oZ
Old 03-21-2004, 06:39 PM   #9405
racer-oZ's Avatar
well i figured it out!
racer-oZ
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
