Old 03-05-2004, 09:22 AM   #9076
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Default Re: weight limit
Originally posted by tomdav
With all this carving do you anticipate being below the 1525g (53.79oz)limit? Or will you add it back via a weighted tunnel cover.
None of the tracks I race at weigh in the car, so I really wont add weight unless I go to a race that I do need to make a weight limit.
Old 03-05-2004, 09:23 AM   #9077
Originally posted by John_S
how are you able to mill so acurately flat faces without going trough the graphite if that makes sense. Are you using some sort of depth stop or just a real steady hand
Everything on that chassis has been done just by eyeball, I have an extremely steady hand, been working with the dremel for just a little while
Old 03-05-2004, 09:40 AM   #9078
John_S's Avatar
hey grate work man i may be inspired to do some dremeling of my own now may try it on a freinds broken chassis first tho
John_S is offline   Reply With Quote
Old 03-05-2004, 09:46 AM   #9079
Just be sure to get a bit that can cut surfaces like that. I tried a 2 face router bit as well but that thing sucked, the 4 sided mill bit works awesome.
Old 03-05-2004, 02:48 PM   #9080
woozer71's Avatar
Trader Rating: 23 (96%+)
Default HANDLING PROBLEMS
I have a losi xxx-s and run it on an asphalt track that has some tight turns in it. I have problems getting the car to turn into corners. It seems to want to go straight on. When I slow right down I loose too much to the other guys. I have tried all types of springs and setups. Can someone please help?
woozer71 is offline   Reply With Quote
Old 03-05-2004, 02:51 PM   #9081
JusBox's Avatar
Default Re: HANDLING PROBLEMS
you running a one way?
JusBox is offline   Reply With Quote
Old 03-05-2004, 02:52 PM   #9082
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Give us a little of your setup info.
What are you running for castor? front swaybars? shock oil? springs?
Does it exit the corner well??
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 03-05-2004, 02:55 PM   #9083
edseb's Avatar
Heh. talking about turn in. I was surprised when I went to Losi's site and saw that most of the guys set up sheets for asphault outdoors were without the use of swaybars. I have my car set up that way and like it, but when do you think it would be a good time to run them, other than carpet?
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 03-05-2004, 03:10 PM   #9084
woozer71's Avatar
No one way. Would one help.
Old 03-05-2004, 03:14 PM   #9085
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Hey what gear are you all using to messure and set you camber?
Looking to get somnething to do that instead of the good old eybal
JohnMatrix is offline   Reply With Quote
Old 03-05-2004, 03:17 PM   #9086
woozer71's Avatar
1.5 degree camber on front
1 degrree on rear
1mm toe out on front
no sway bars
5mm ride height on front
5.5mm on rear
purple springs on front
silver on back
50 oil front and rear
The back end is fine. Does not slide on the rear.
Old 03-05-2004, 03:20 PM   #9087
woozer71's Avatar
Tamiya camber gauge
Old 03-05-2004, 03:20 PM   #9088
edseb's Avatar
I use a camber tool which is made by RPM (I think?). They run only a few bucks ($10?)
Carl Hyndman
Old 03-05-2004, 04:55 PM   #9089
RCTech Member #2
TSR6's Avatar
Part of the reason could be the surface. If it's really bumpy, you want the suspension to do it's work, and not be bound up by a swaybar. I know I ran just the thinner swaybars outdoors.
Johnmatrix - I use a schumacher camber guage.
Woozer - Have you tried lighter springs in the front? The hardest spring I even really run for rubber tire is the blue spring, occasionally green.
Troy
RCTech Member #2
Old 03-05-2004, 05:13 PM   #9090
JohnMatrix's Avatar
hey Troy,
Thanks for the heads up. Where can I pick that up online?
Thanks again.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
