Old 03-05-2004, 09:07 AM   #9061
Randy Caster's Avatar
Trader Rating: 45 (100%+)
All of that is done by hand with a dremel...
Old 03-05-2004, 09:11 AM   #9062
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Dremel? What happened to the mill?
Jon Kerr is offline   Reply With Quote
Old 03-05-2004, 09:13 AM   #9063
It would take more time for me to make the jigs to hold the chassis then it would to dremel the thing 5 times over... I use a mill bit so it makes pretty quick work of the graphite.
Old 03-05-2004, 09:18 AM   #9064
Jon Kerr's Avatar
Not like last time that took you for ever.
Old 03-05-2004, 09:23 AM   #9065
Send a message via AIM to ZER01
DREMEL! By hand! No friggin way! Which bit and what speed? Nice work Randman. Can you post a pic of the bit?
ZER01 is offline   Reply With Quote
Old 03-05-2004, 09:31 AM   #9066
This might be taking about the same amount of time, do you know how much of a bitch it is to get that lower surface level after I hack off the top surface?
Old 03-05-2004, 09:33 AM   #9067
Jon Kerr's Avatar
I know I'm not going to try it.
Old 03-05-2004, 09:34 AM   #9068
Onsrud.com sells the bits, I use #54-000
Download their catalog, they have tons of mill bits that will work great with a dremel. Just be careful, because if the bit starts to chatter, you can cut off 1/4" more than you wanted to in less than a second, you gotta keep a firm grip on the dremel...
Old 03-05-2004, 09:36 AM   #9069
I wanted to do it on the first one, but with that bit... it would have taken months. Even on Kevin's chassis I started with a dremel bit before I figured out to chuck this bit up in the dremel, and it took forever to get so little done.
Old 03-05-2004, 09:39 AM   #9070
Jon Kerr's Avatar
Did you go all the way through on Kevin's or just the surface like on your's?
Old 03-05-2004, 09:43 AM   #9071
Kevin's is all the way through, it's made for asphault racing with stock/19t. Mine is just surfaced because I'll be running mod, and I may go up to the carpet race next weekend so I still need it really stiff.
Old 03-05-2004, 09:58 AM   #9072
I do recall someone milling out alot of the chassis years back and then using some type of saranwrap or clingwrap to cover the areas up from debris.
Old 03-05-2004, 10:00 AM   #9073
tomdav's Avatar
Trader Rating: 41 (100%+)
Default weight limit
With all this carving do you anticipate being below the 1525g (53.79oz)limit? Or will you add it back via a weighted tunnel cover.
Tom
Camas WA
davesrctracks.net
premierrcpdx.com
tomdav is offline   Reply With Quote
Old 03-05-2004, 10:10 AM   #9074
Jon Kerr's Avatar
usually when you lighten a car, what you're allowing yourself to do is bring it back up to weight by adding weight WHERE you want it. Some cars are naturally heavy on one sode or the other. So by bringing the weight down you can add weight to the lighter side to balance the chassis better.
Old 03-05-2004, 10:18 AM   #9075
John_S's Avatar
how are you able to mill so acurately flat faces without going trough the graphite if that makes sense. Are you using some sort of depth stop or just a real steady hand
John_S is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
