Old 02-23-2004, 07:06 AM   #8911
spenzalii's Avatar
Send a message via AIM to spenzalii
It's a crying shame. It's cold and I odn't have the time to run at the area carpet track (45 minutes out), so I ended up converting my XXX-S into a drifter. I cut some PVC pipe, slapped them on some rims and went to town yesterday. Quickest conversion I've done yet. With nitro coming around the corner, it wouldn't have got much run once the weather broke. Quite fun, actually. I'll still go get the belt conversion, just in case I do get some asphalt running in between nitro time.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 02-23-2004, 07:27 AM   #8912
Default Re: TRC Foams
Originally posted by stumper1
Hey guys!!
I decided to try foams - just been racing stock spec/rubber. I bought a set of TRC foams and went to put them on and notice the hole in the center is not big enough - is this common?
Great name btw! I noticed the same thing yesterday when putting on any rim besides the losi ones.....I think its common thing.
stumper is offline   Reply With Quote
Old 02-23-2004, 07:29 AM   #8913
RichO's Avatar
Default Yokomo clamping AE hubs for XXX-s
Does anyone know who would have the yokomo AE hexs for foam tires in stock? I am looking for the clamping hubs but I cannot seem to find them in stock anywhere.
RichO is offline   Reply With Quote
Old 02-23-2004, 10:17 AM   #8914
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Hey guys!!
Most rims are made for the metric sized axles so thats could be why some fit tighter and the hole needs to be enlarged a little with a reamer. But yes it is common to have rims that fit tight over the axle.
RichO.....try Yokomo direct.....or Stormers maybe.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 02-23-2004, 08:31 PM   #8915
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
RichO, I have them in stock and they will be on the TC3 page shortly.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-24-2004, 07:23 AM   #8916
Send a message via AIM to ZER01
Found a tip...
This defeats the purpose of setting droop via shock ball end but it does eliminate the "slop" between the shock ball and the ball cup. I've notice more and more slop between the ball and the ball cup holder each time I run the car and the way to take the slop out is to tighten the ball cupp on more untill the ball freely moves yet the slop is removed from the pressure of the shock shaft on the ball cup.
Another way is to eliminate the slop and still adjust droop via shock end is to use the standard camber link ball cups and ends.
ZER01 is offline   Reply With Quote
Old 02-24-2004, 02:33 PM   #8917
NVisible's Avatar
i must say the hardware included with the xxx-s is the absolute WORST i have ever worked with. Doing the graphite conversion, even with pre-tapping the holes ive stripped 3 screws. ive never seen such a weak material used in screws before. Now i have to risk ripping my graphite chassis to shit with my dremel just to get one screw out.
sorry i just felt the need to vent
NVisible is offline   Reply With Quote
Old 02-24-2004, 02:41 PM   #8918
JohnMatrix's Avatar
Send a message via AIM to JohnMatrix
Thats Disappointing to hear.
I've found that the easyout screw set , #0, works very well on striped screws.
JohnMatrix is offline   Reply With Quote
Old 02-24-2004, 03:07 PM   #8919
EricF's Avatar
What brad of wrenches are you using? The quality of your tools play a major role in striping out the allen heads especially the 1/16 and .050.
That's still to bad that happened.
Eric
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 02-24-2004, 03:35 PM   #8920
NVisible's Avatar
yea, im going to invest in some Integy drivers before i continue. I have a screw set coming from rcscrewz.com as well. And i think im going to buy a proper tapp for it .
dad and i just drilled the head off the sucker.
sorry if i offended anyone with my little rant
Old 02-24-2004, 03:50 PM   #8921
Get better tools...it happens sometimes if your tools are old. I would stray away from the integy ones, I had them a long time ago and the tips wore out pretty quickly. Just my opinion though.
James Nguyen is offline   Reply With Quote
Old 02-24-2004, 04:00 PM   #8922
NVisible's Avatar
hrm!. can you reccomend anything?
Ive heard the Team Associated set is good
Old 02-24-2004, 04:13 PM   #8923
EddieO's Avatar
R/C Tech Charter Subscriber
Hudy makes nice stuff, so does Losi and Trinity. I do have some integy wrenches.....more like my back up wrenches or the ones I loan out without a worry of getting it back.....
I've never had a problem stripping any of the screws I got with a losi kit.....
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 02-24-2004, 05:16 PM   #8924
hobbipro's Avatar
Trader Rating: 21 (100%+)
Integy wrenches are just fine, I've had a set for 2 years now and only broke the .50 just because I had some muscle behind it. I agree the losi and probably the Tamiya flat head screws are the worst, they are made from cheep pot metals or something. I replaced my XXX-S with a Ti set I got off of ebay for $35.
hobbipro is offline   Reply With Quote
Old 02-24-2004, 05:26 PM   #8925
I have the Trinity wrenches and nut drivers. They are nice but a tad bit on the expensive side. If I were to get anything else it would have to be Hudy. Hudy just released some of there less expensive version.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
