Old 02-19-2004, 07:47 PM   #8836
mike_Webb's Avatar
Send a message via AIM to mike_Webb
For you guys that run foam tires. What are you doing to get 5mm rideheight front and rear when your tires are 57mm or below? Right now my tires are at 57mm and my shock collars are bottomed out and I can barley make 5mm?
Do you guys have a adapter that allows you to make your shock springs go lower for the collar?
Mike Webb
mike_Webb is offline   Reply With Quote
Old 02-19-2004, 08:00 PM   #8837
Lightbulb Ride Height
mike Webb- try placing a .100 spacer between the lower spring seat and the shock rod end. Judging by the set up sheets the Team Losi drivers are using .100 external limiters to control body roll so this might kill two birds w/ one stone.
xxxs-bill-RCCar magazine had an article like a year ago with Todd Hodges basic (asphalt?) recommended setup. You might be able to find it online!
As a matter of fact it's in the May 03 issue
Poppa Ray is offline   Reply With Quote
Old 02-19-2004, 08:02 PM   #8838
lazyboy's Avatar
Send a message via AIM to lazyboy
FOR ME WHEN THAT HAPPENS I JUST GO TO 4mm RIDE HEIGHT AT THE TRACK WERE I RACE, BUT IF 5mm IS THE LIMIT THERE FOR U IM NOT SURE U CAN GOTO THE TODE HODGE THREAD AND ASK HIM
lazyboy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 02-19-2004, 08:05 PM   #8839
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Mike, that's why you run 4 mm ride height....
And with the TC3 you never have ride height problems...
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 02-19-2004, 08:12 PM   #8840
mike_Webb's Avatar
5mm ride height is enforced at our track sometimes .
I wonder why Losi makes their harder springs in 1inch springs or they don't thread the shocks all the way down???
Old 02-19-2004, 08:18 PM   #8841
Why...it's foam tire...
After you over-limited your shocks did you unscrew the shock end to get more travel? One thing I did when I had that car is use schumacher ballcups as shock ends and ballstuds on the arm, that allowed me to make ride height fine.
USVTA Member #211
Old 02-19-2004, 08:40 PM   #8842
mike_Webb's Avatar
That is what I just figured out .
I am going to use a taller ball cup on the shaft to do it. it doesn't matter if I over limit or have no internal limiters int he shock. The Collar is to the bottom of the threads and the spring will not reach far enough to make ride height. The car will always come to rest at 4mm.
Now with the new ball cup on the bottom of the shaft I can make rideheight .. thank god for those RPM ball cups with 2 inches of threading area
it is a general rule about the 5mm rideheight. Every indoor track that I have been too has been 5mm. Even the snowbirds was 5mm
Old 02-20-2004, 04:26 AM   #8843
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default Re: Re: t hodge article on rubber tire setup.
Originally posted by XXX-S Bill
Go to the TEAMLOSI.COM site for it...And others.
I should have been more specific...I was looking for the article in rc car or extreme that todd wrote with regards to rubber tire tuning/setup...I had purchased the magazine that had the article on foam tires.
Sorry for the confusion.
Jamie
J.Gonzalez is offline   Reply With Quote
Old 02-20-2004, 04:44 AM   #8844
Send a message via AIM to munrath
Mike,
Use the ride height spacers that come with most RTR's, just purchase a set of those and you'll be fine.
Thanks,
Mark
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Old 02-20-2004, 04:56 AM   #8845
hobbipro's Avatar
Trader Rating: 21 (100%+)
Default Hex adapters
I'm new to the losi xxx-s, so far love the car, But hate the wheel hexes comming off when the tire is taken off. I've breifely read something about AE ones being used. My question is since they are thicker not much threads will stick out of the wheel. Is there another mod I'm missing to get more threads? I found some clamping type on integy web sight if they will work.
hobbipro is offline   Reply With Quote
Old 02-20-2004, 05:31 AM   #8846
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
there are a few options, keep changing the nuts out, put them on backwards (so the nylon part is on the threads), machine the nuts down some on the back face, and I have also heard of ppl using TC3 axles b/c they have more threads, I cannot confirm that tho...
brians11 is offline   Reply With Quote
Old 02-20-2004, 06:52 AM   #8847
STLNLST's Avatar
Trader Rating: 19 (100%+)
Default Re: Hex adapters
I had AE axles on my XXXSGP and since they were longer than the losi axles I could thread the nuts on all the way and not have to worry about losing a nut and I also used the stock AE wheel hex and it never came off in the wheels.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-20-2004, 09:07 AM   #8848
lazyboy's Avatar
when over limiting on the short shocks in the front, should i use the .60-tho spacer like in the rear or the .30-tho??
Random Guy
FT B4
Trackside hobbies
Old 02-20-2004, 09:39 AM   #8849
EricF's Avatar
It would seam that you can use whichever one you like. It will affect how far you need to screw or unscrew the shock end to get your desired droop and it may also have an affect on ride height.
On a setup from B. Flack he used .12 limiters inside the shock.
Eric
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 02-20-2004, 10:55 AM   #8850
NVisible's Avatar
Default Stainless Screw Kit
After seeing my friend go through 2 broken screws in his chassis this week, it got me very interested in aftermarket screws for my XXX-S. Im wondering if stainless would be a good choice (www.rcscrewz.com on ebay specifically) Has anyone used them?
I know theres a post in this thread somewhere about them, but 250+ pages is alot to sift through. I apologise for the double post
NVisible is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
