Old 02-17-2004, 03:22 PM   #8821
My main problem with a one way was on the straight. It would not accelerate straight and taking off from a dead stop it always pulled to the right severly. Whats up with that. I instantly went faster with a diff. I'm not the type that wrecks alot. I know how fast I can go with a given setup and drive accordingly.
Homer Allman is offline   Reply With Quote
Old 02-17-2004, 03:26 PM   #8822
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
That sounds like the right front one way bearing may have been bad. When you are on power with a oneway, the front wheels are locked, just like a spool. So if the car is pulling to the right, your left front is driving faster than the right. soundls like the right front oneway bearing is slipping or something. You said all you changed was the oneway to the diff and it went away?
Jon Kerr is offline   Reply With Quote
Old 02-17-2004, 03:34 PM   #8823
Yes when I changed it went away. I'll look into a new way when the season starts again to give it a try.
Old 02-17-2004, 03:43 PM   #8824
Jon Kerr's Avatar
Yeah, I've never had that problem down the straight. At least not since I got rid of my TC3
Old 02-17-2004, 03:45 PM   #8825
It was weird to say the least.
Old 02-17-2004, 07:39 PM   #8826
THeGame's Avatar
Send a message via AIM to THeGame
Default Homer
Ask that dude for help..... he knows all the little tricks.....
THeGame is offline   Reply With Quote
Old 02-18-2004, 06:01 AM   #8827
pucho's Avatar
Send a message via AIM to pucho
Originally posted by J.Filipow
Pucho- What is the status with RPM in Orlando? I used to run at CPT and then FCCR in Jacksonville pretty frequently, both of which were fun carpet tracks...I am looking forward to running carpet at RPM soon.
It should be a few more weeks all of the construction (major) should be done by sometime next week. We will be updating the site with a schedule and more info as soon as we get the go ahead. You can go to the rcscorignpro site for some pics.
PICS
Luis
pucho is offline   Reply With Quote
Old 02-18-2004, 03:13 PM   #8828
Post One Way, Spool, Diff
Preference for these setups depends alot on driving style!!! I almost never use brakes and I like to throttle steer. I went from a diff to a one way and instantly picked up .5 sec/lap on asphalt!!! All the guys at the carpet track run/ran spools. I went from a spool to a diff and found .2 sec/lap. For me the following is true.
Oneway=carries speed during turn in and mid corner,great on-power steering.
Diff=good all around control and balanced steering/power but doesn't carry speed well unless ran loose(not good for mod motors)
Spool=off power push,doesn't carry speed in the corner,great on power steering
Honestly If the carpet track reopens I'll probably try a one way there at least once. I also can't wait for BK Bones to be released, talk about carrying speed!!!!
Poppa Ray is offline   Reply With Quote
Old 02-19-2004, 11:53 AM   #8829
imjonah's Avatar
Default Snowbirds-19t Oval Touring class
I think this is the second year that an oval touring car class was run.
I wonder if any one has any information on this class.
besides 19turn motors were their any other special rules?
How were the XXX-S setup to run in this class.
I would be interested on what if any modifications were made or allowed.
Also any advice on how to best drive a touring car on an oval track would be appreiciated.
Thanks in advance,
imjonah is offline   Reply With Quote
Old 02-19-2004, 12:29 PM   #8830
EddieO's Avatar
R/C Tech Charter Subscriber
Umm....I think the best way would to turn left around four times, go straight some.....and don't hit anything!
I don't think anyone really paid much attention to the touring oval....was kinda slow compared to the other oval classes. I did see a few xxxs oval cars, but didn't really watch.
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 02-19-2004, 02:01 PM   #8831
peter_robinson's Avatar
Trader Rating: 21 (100%+)
hey guys just FYI, the associated clamping hubs suck, if you are gonna use the associated hubs, use the plastic ones.
the reason being is that i am finding the the AE clamping hubs will get shoved in against the bearing and bind up the drive train, this will hapen even without hitting anything.
the best setup by far is to use the stock losi hubs, with a tamiya 1mm wheel spacer, no binding this way.
For orders or inquiries, email sales@rc-trim.com. Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 02-19-2004, 03:08 PM   #8832
Post AE hexes
From what I understand the AE hexes are going to be moot point on carpet as the new trc 28mm rims have a 2 mm offset. This is supposed to eliminate the rubbing @ max steering input and bring the wheel base up to full max width
Old 02-19-2004, 07:44 PM   #8833
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default t hodge article on rubber tire setup.
Any one have a copy of T. Hodges article on xxxs setup with rubber tires that they can post or email. I have the one for foam tires.
thanks,
Jamie
J.Gonzalez is offline   Reply With Quote
Old 02-19-2004, 08:08 PM   #8834
Default Re: AE hexes
exactly, but in the meantime we are stuck with having to use the alternatives
Old 02-19-2004, 08:09 PM   #8835
Still Bill's Avatar
Default Re: t hodge article on rubber tire setup.
thanks,
Jamie
Go to the TEAMLOSI.COM site for it...And others.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
