Old 02-16-2004, 02:51 PM   #8791
racer-oZ's Avatar
R/C Tech Charter Subscriber
Default Fike
Keep in mind the "low" roll center blocks that come with the XXX-S Graphite car are actually "mid" roll center blocks. If you want the full "low" roll center blocks you would have to buy them from speed tech rc cuz I think Matt Francis quit making them.
The Full low roll center blocks are .150 shorter than the original XXX-S blocks and the Mid low roll center blocks are .075 shorter than the original XXX-S blocks.
racer-oZ
racer-oZ is offline   Reply With Quote
Old 02-16-2004, 02:52 PM   #8792
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Default Re: Fike
racer-oZ
Or cut your own
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-16-2004, 03:00 PM   #8793
EricF's Avatar
Default Re: Fike
Originally posted by Poppa Ray
Yeah they're included.
Thanks, do know which parts bag their contain in? Never mind... I'm sure that I'll find them when I take the time to look for them.
E
R oZ,
Ok I understand that the mid lrc come with the kit... do you know if they are the sme ones that Hodge refers to in his setups?
thanks.
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 02-16-2004, 05:22 PM   #8794
J.Filipow's Avatar
Trader Rating: 15 (100%+)
Fike- Todd just did a great XXX-S article in the March 2004 issue of R/C Car...check it out.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 02-16-2004, 05:50 PM   #8795
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
fyi, you can still get the Matt Francis low roll center mounts.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-16-2004, 08:31 PM   #8796
racer-oZ's Avatar
Fike, I think their setup sheets usually list the mid roll center blocks, but sometimes they will list in the notes section of the setup sheets when the use the full low roll center blocks. The full low roll center blocks are usually too aggressive steering wise, you would want to shim them up a little to tone them down. I think that is why the kit comes with the mid roll center cuz it is the best of both worlds and a great starting point for most tracks.
Hope this helps! Maybe we'll see some of the XXX-S faithfuls from this thread at the Mod nats in Portland this summer. I enjoy keeping up with this thread.
racer-oZ
Old 02-16-2004, 09:11 PM   #8797
Still Bill's Avatar
racer-oZ
Thanks for advising us about the three different roll center blocks. I thought there were just two.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 02-17-2004, 07:09 AM   #8798
Bad-Andy's Avatar
Originally posted by pro3racer
thats might be hard to cut the plastic teeth, but it might help.
It was really easy actually, I just took the very small round cutting bit, the one shaped like a small sphere, for the dremel and went to town and cleaned up the areas next to the sides where the dremel couldn't reach with an Xacto. And then since I was at it I narrowed the belt some, to about a little more than half width. And when it was all back together it was nearly as free as any shaft car at our track. I haven't had a chance to try it out b/c I'm not a fan of foam tire carpet racing. I prefer to run outdoors on the asphalt with rubber tires. But I figured if some of the X-Ray/ Fantom team guys were doing it with their cars and running 7 and 8 turn motors, my 19T shouldn't have any issues.
Bad-Andy is offline   Reply With Quote
Old 02-17-2004, 08:05 AM   #8799
pucho's Avatar
Send a message via AIM to pucho
Hello:
I come here because Im considering building a XXS to try out. Im looking to get the G+ version, now I know about the cutting the the theeth on the belt to make it freeer, but can you guys guide me along as to what other tricks you guys are doing to the car. Also any parts that you guys would recomend that are not included in the kit. I was looking around and I see that there are spur gear adapters for the car they are sold as a 23t or 24t versions which one are you guys using? Any help would be greatly appreciated.
Luis
pucho is offline   Reply With Quote
Old 02-17-2004, 08:06 AM   #8800
EricF's Avatar
Thanks, for the quick answers... I do have that article, and your right, it is very helpful.
Another question, when cutting teeth off the belt, does one only remove the lump of the teeth? Did that make since?
Thanks.
Old 02-17-2004, 08:12 AM   #8801
EddieO's Avatar
Puncho - No need for the spur gear adapter, the stock losi spurs work great, especially the Kevlar unit. Other parts that are worth getting are a one way(if you plan on running rubber, especially stock), the aluminum threaded shock collars from trinity(available in blue or red), the titanium nitride hinge pins from losi, and maybe a titanium screw kit......other than that, the rest is just tuning stuff that you can pick up later as needed.....probably would be wise to find the hot losi setup at your local track, so you pick up the stuff you need before you build it, as it may use different shock pistons, springs, hub carriers, or spindles.
Fike, just use some cuticle (spelling??) cutters and cut it flush with the space between the teeth already....take your time and remember you can ALWAYS cutoff more, but can't put it back on. Make sure you order the new belt system from your local hobby shop....easily worth the cash.
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 02-17-2004, 08:27 AM   #8802
pucho's Avatar
EddieO: thanks for the help
Im planing on racing on carpet , any specific parts that you know of that would help.
Old 02-17-2004, 08:28 AM   #8803
I can't wait to get those new parts.
Homer Allman is offline   Reply With Quote
Old 02-17-2004, 08:28 AM   #8804
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I've never run on carpet but from what I've been told, sway bars and heavy springs.
Jon Kerr is offline   Reply With Quote
Old 02-17-2004, 08:50 AM   #8805
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Swaybars, anything over 25lb springs and the offset rear. I think that is about all the major stuff you need.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
