Losi XXX-S
#8731
Kevin: Hey man, glad to see that you survived the trip home from Snowbirds.
Question for you: Do you have metal/alum. AE hexs for your car? If so, which ones did you get?
I am looking to replace the composite AE ones with something a little stronger and truer.
Later,
Rich
Later,
Rich
#8732
Trader Rating: 32 (100%+)
RichO.....is this Richard Orr???
Yeah I was surprized that I made it home after the way I was packed into Busse's honda for the ride to the Airport.
I use the Yokomo Clamping hexes for the TC3....they are sweet.
Send me an email so we can stay in touch.... [email protected]
Maybe you can make it up to the ROAR nats in march.....
#8733
Originally posted by J.Filipow
Info on the new belts...
http://www.teamlosi.com/newprod/2004..._drivebelt.htm
there are two part numbers for the new belt, for the xxxs... LOSA3280 and LOSA3281... would anyone know whats the difference between the two?
#8735
Kevin: Yes indeed....
Did you have to modify them at all or bolt them on and away you go? Definitely going to order some.
Rich
Rich
#8736
AE makes their own clamping hexes now that work great on the xxxs with no mods. I just put some on the new car I built for the snowbirds and they fit perfect.
Later EddieO
Later EddieO
#8737
The Yokomo ones are a direct fit.....I also use TC3 stub axles on my car as the threaded part is a little longer then the stock XXXS ones so the wheel nut goes on further when using the TC3 style hexes.
#8738
Regional Moderator
have you guys seen this chassis any where?
#8740
Regional Moderator
Originally posted by jkerr0043
Looks like a CF sticker on a G+ chassis to me.
I dont think so
#8741
wow that is a work, of art where can I get that chassis
#8742
It looks like that chassis took a trip to Aqua Designs for some TLC. Looks nice.
#8743
it is a sticker...you can see on the first pic, where it rubbed through....
