Old 02-08-2004, 06:27 PM   #8701
EddieO's Avatar
R/C Tech Charter Subscriber
No, no BK Bonez....Todd couldn't give any out, we'll see at the race up here if antes up with my ferrari staring him down.
We did get black belts and peter got a professionally drilled shock tower(with the higher in between holes).
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 02-08-2004, 06:46 PM   #8702
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Later EddieO
I guess it never hurts to try, now does it?
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-08-2004, 09:13 PM   #8703
ajg
Registered User
ajg's Avatar
Default gearing
How many teeth does the stock yellow spur have on it? Also what pitch is it, 48 or 64?
ajg is offline   Reply With Quote
Old 02-08-2004, 10:22 PM   #8704
JitsuGuy's Avatar
Send a message via AIM to JitsuGuy
88 teeth and I believe it's 48 pitch.
J
JitsuGuy is offline   Reply With Quote
Old 02-09-2004, 05:14 AM   #8705
Can somebody tell me what they mean on the setup sheets under shocks where it stands limiters?
I see that a lot of people are using the 6 degrees hub carrier in front, what diffrence does this make conta the 4 degreees?
sturla is offline   Reply With Quote
Old 02-09-2004, 07:51 AM   #8706
STLNLST's Avatar
Trader Rating: 17 (100%+)
what they mean by limiters is placing spacers inside the shocks and setting the droop by shock length to avoid the flexing of the bumper with the stock droop screws.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-09-2004, 08:07 AM   #8707
Still Bill's Avatar
Default Limiters part number
The Losi part number for the shock limiters is A-5050. Think they cost me $2/pack. They are just round plastic spacers with a specific height.
Per Todd Hodge, he opens his limiters up a bit on one side (c-shape) to be able to snap them on and off the shock shafts.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 02-09-2004, 08:47 AM   #8708
EddieO's Avatar
Limiters are typically used to limit up or down traval(or both in some cases). A lot of the Losi drivers are now using limiters and placing ball cups on the end of the shop shafts to set droop, as it isn't very accurate with the stock bumpers because they flex. So, they use the bottom shock collar to adjust the droop height up or down by loosening or tightening the collar. It's VERY time consuming compared to the stock droop setup, but its a ton more accurate. If yer worried you probably could buy the extra rigid bumpers. I am working on some aluminum/carbon fiber pieces to replace the stock ones. Some drivers tapped out their arms and did it tc3 style to set droop.
As for the hub carriers, the way it was explain to me was at 4 degrees, you usually would run 2 degrees of kickup(or antidive, I can't remember, I am WAY sleep deprived from snowbirds!). With the 6 degress, you run zero kickup. The 6 degree setup will make the car less twitchy and smooth out the steering. I switched to the 6 degree setup in the 2nd heat of the club race and I didn't like it. Felt like I was riding in the car with my mom driving!
Later EddieO
www.teambrood.com
Old 02-09-2004, 01:29 PM   #8709
Fran's Avatar
Trader Rating: 131 (100%+)
Default Team PRP products
Hey guys, I was doing some research for a friend with a XXXs. His sedan he got in a trade, and from what I gather from Steve Wang@Speed Tech RC, the shock towers are from Team PRP. They are graphite, with a million (ok 56 ) holes in the rear shock tower. Any info on thier web site, or how to get in touch with them? He decided to stop on the straightaway and adjust his radio, and I gave his ride a carbon fiber enema : I know it wasn't my fault, but I feel bad anyways... Any help would be appreciated!!!
Fran
Frantastic Batteries
Fran is online now   Reply With Quote
Old 02-09-2004, 03:13 PM   #8710
RCTech Member #2
TSR6's Avatar
http://www.teamprpracing.com/
Troy
RCTech Member #2
Old 02-09-2004, 03:36 PM   #8711
Fran's Avatar
Thanks for the help!!!!
Old 02-10-2004, 03:15 PM   #8712
Post PRP shock towers
There is a vendor on eBay, richeddy, selling prp shock towers front AND rear for 11.95 a set. I bought a set a month ago for my asphalt car because I run 4 deg anti squat and needed the lower holes to get the right droop. I liked them so much I bought a second set for my carpet car last week. The front tower is also a bonus since it already has the hole drilled up and between #2 and #3 for the camber like most of the pros are running.
Poppa Ray is offline   Reply With Quote
Old 02-10-2004, 03:48 PM   #8713
Jon Kerr's Avatar
I got a set of them too. So far so good. The look good too.
Jon Kerr is offline   Reply With Quote
Old 02-10-2004, 06:28 PM   #8714
pro3racer's Avatar
okay, i have a weird phenomonom going on here. At the bigging of the race, all my cambers are set to where i want it, but ant the end of the race, my right rear has only about 1/3 of the tire touching(no gauge availalbe.) I instantly think that the turnbuckle is stripping out the ball cup, and sliding in, because the right one is significantly shorter than the left side. So i try to push and pull apart the two, and they don't move, so how can it be stripped, i can't move it, i think it may be vibrations, but could it be something else?
pro3racer is offline   Reply With Quote
Old 02-10-2004, 06:32 PM   #8715
Send a message via AIM to ZER01
Do they links look like they have not changed their length? Also check the ballcups to see if they are bent. That's about all I can think of besides your wheels being warped, look at the wheels for warpage also.
ZER01 is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
