Old 10-24-2001, 10:51 AM   #841
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Thanks.... I know I don't want to use the Aluminum screws in the front and rear piviot supports.... I would think that in a big crash a lot of force is applied to those pieces and I would hate to snap the screw off .
Mike
mike_Webb is offline   Reply With Quote
Old 10-24-2001, 02:50 PM   #842
mike_Webb's Avatar
Which Power Suppy would you guys get... Pyramid or Rivergate? Looking to get the 30-35amp model
Mike Webb
Old 10-24-2001, 02:53 PM   #843
Trader Rating: 19 (100%+)
The Rivergate stuff is really solid. You still see guys that bought them 8 years ago and still running them. The newer ones have a slim design as well.
Go with the Rivergate. I have had a few Pyramid that just wouldnt hold up.
MDawson is offline   Reply With Quote
Old 10-24-2001, 02:55 PM   #844
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i have had my rivergate for 6-7 years..it still runs great....
Matt M. is offline   Reply With Quote
Old 10-24-2001, 03:05 PM   #845
mike_Webb's Avatar
Thanks Guys
Old 10-24-2001, 03:14 PM   #846
mike_Webb's Avatar
One other question... Beteween the P-94, Reedy/Fantom TI, Peak/Orion Chrome/Auora... what mod motor would you suggest.... or any other that I didn't mention. I am looking to get a 8 Single. Do the Nebula/Chrome Touring bascically the same thing?
Old 10-24-2001, 03:20 PM   #847
I am in the D4/P94 Camp. I would place a second option to the Fantom line of TIs.
I would based the decision on availbility of brushes (p94 takes a different size) and extra arms.
Cost-wise they are all about the same level.
Old 10-24-2001, 03:29 PM   #848
mike_Webb's Avatar
I have decided to give the P-94 the go ahead... Should I get the Regular Single Wind or the layered double wind? This is a technical track that needs lots of torque. I think Andrew G runs a 6 or 7 turn Fantom Single.
Old 10-24-2001, 03:32 PM   #849
Remember that the lower winds are much harder on the batteries. Start with a double.
Old 10-24-2001, 08:54 PM   #850
yodace's Avatar
R/C Tech Charter Subscriber
anybody have a carpet set up with out using congo springs? Suggest please. Is the kit set up good for carpet racing?
yodace is offline   Reply With Quote
Old 10-24-2001, 09:28 PM   #851
yo,
I beleive this was Andrew Grays setup from Octoberfast:
Front: oil: 70, piston: 56, #4 shock position, #2 camber link, arms forward, 2 deg. kick up, 4 deg. castor, .062 sway bar, blue congo springs, standard diff, low roll center, #2 on droop guage
Rear: oil: 70, piston: 56, #4 shock position, 1B camber link, outside on lower arm, -2 camber, 0 antisquat, 5 on droop guage, arms in middle, low roll center
Other: 3.5mm ride height, JACO Plaid front, purple rear
Old 10-24-2001, 09:51 PM   #852
yodace's Avatar
md
all i have are the kit springs including yellow orange and black,and purple.
Have you tried the kit set up on carpet?
Is Paul L 's setup a good one to use, ? from the losi website.
Only raced outdoors?
Old 10-24-2001, 09:55 PM   #853
Send a message via Yahoo to Doug Gaut
MDawson, You seem to be very knowledgeable on the XXX-S and I was wondering if I could get some setup ideas from you? We have a Very High Bite concrete (tight) track that we race at. I have raced on carpet and the bite on this concrete is equal to or higher. I used Paul Lemieux's carpet setup with the exception of: 57 pistons front, front diff, 1.5 camber, stock caster, purple springs front, blue springs rear, rear droop 3, .062 front swaybar. I have ran the stock setup only to have the car pin dramatically. With this setup the car was stable but had too much push entering and during the middle of the corner and very lazy on exit. It didnt transition fast enough. For tires we tried 33r/blue insert, 27r/blue insert,27r/red insert, 138g/firm insert, and finally ended up using med yok/soft molded insert. The fast guys were running 33r/firm yok foam inserts!? I tried them and the car became very unstable at all speeds. Isnt the norm to use firmer inserts as the bite increases? Any observations and ideas would be greatly appreciated by at least 4 of us XXX-S racers.
Thanks Doug
Doug Gaut is offline   Reply With Quote
Old 10-24-2001, 09:55 PM   #854
yodace's Avatar
what are the losi's version of the congo springs?
Old 10-24-2001, 09:57 PM   #855
There is only one carpet track in southern California and havent been there to test out carpet.
Other than that track all of the other tracks are outdoors with exeption for So Cal.
I kept Grays setup as something to try on carpet. As it gets further into the carpet season, you'll be sure to find more options.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
