Losi XXX-S
#8431
Mark David,
Buy the BRP front bumper and you'll be very happy.
http://horizon.hobbyshopnow.com/serv...=ALL&tag=qsrch
Mark
Mark
#8432
Tech Legend
Trader Rating: 51 (100%+)
Hey Mark when did you get a Losi? No more Yoke!!!! I got a TC3 as my Yoke kept gitching with 2 different radios and then I sold it to a buddy and he kept glitching with it as well so he just sold it. Too bad as it worked pretty good.
#8433
Will that same bumper help with the front suspension/droop screw flex problem?
#8435
Registered User
Any one going through one-ways on carpet with rubber tires? I went through three last weekend! Either the bearing pins came out or they seized completely.
#8436
The one ways can be quite weak sometimes, I carry some extras when I go to the track. I saw quite a few go out this past weekend.
#8437
You should get the Tech-Racing one way. These are bullet proof. They have one piece metal outdrives and 6mm one way bearings.
#8438
Kevin K.. Thanks for the words.. the car was good all weekend. Showed all those shaft cars what was up. Anyways.. heres the setup I ended up with. If I forgot anything let me know.
Front
Oil- Losi 40
Piston- 57
Spring- Trinity Purple congo
Caster- 6 degree
Link location on tower- above and between 2 & 3
Shock location on tower- 2
Roll center- Low
Droop- 2
Toe out- 0
Camber- 1
Ackerman- forward and flipped
Pivot support- 0f
arm spacing- front
Sway bar- .070
Tires- 30mm cyan cut to 28mm
Rear
oil- Losi 40
Piston- 56
Spring- Trinity Blue congo
Link location on tower- 1
Roll center- Low
arm spacing- back
Toe in- 2 degrees
Droop- 2
Pivot support- 0R
Camber- 1
Hubs- off set
hub link locaton- A
Tires- 28mm Magenta
Sway Bar- .050
Body-Losi Alfa
Batteries forward
Ride hieght, 4.5mm front and rear.
AE hexes front and rear
Gearing- Stock w/ a Monster- 32/128
19T w/ a C2- 38/128
Front
Oil- Losi 40
Piston- 57
Caster- 6 degree
Roll center- Low
Droop- 2
Toe out- 0
Camber- 1
Pivot support- 0f
arm spacing- front
Sway bar- .070
Rear
oil- Losi 40
Piston- 56
Roll center- Low
arm spacing- back
Toe in- 2 degrees
Droop- 2
Pivot support- 0R
Camber- 1
Hubs- off set
hub link locaton- A
Tires- 28mm Magenta
Sway Bar- .050
Body-Losi Alfa
Batteries forward
19T w/ a C2- 38/128
#8439
The Evicerator
Good job at the race Bobby...and welcome to Losi
#8440
Thanks dude!
#8441
Bobby Flack, good run. What size were your foams after your main?
#8443
Are the AE hexs wider, and increase the width of your car? I'm thinking they prevent you from having to grind anything down when running 28mm.
#8444
#8445
