Old 01-03-2004, 08:35 AM   #8311
pro3racer's Avatar
haha, my car has that too. i bought it, and it has one Rear A-arm with one hole, and one with two, but i got standard hubs, so there both on the outside, so nothings wrong. I;m just waiting to break a rear arm so i can replace them.
pro3racer is offline   Reply With Quote
Old 01-03-2004, 08:57 AM   #8312
babytoy101's Avatar
Talking belts for XXX-s!
anybody here using a aftermarket belts for XXX-S or know the pitch lenght, width, pitch and lenght of XXX0S belt??
babytoy101 is offline   Reply With Quote
Old 01-03-2004, 09:50 AM   #8313
Default Re: belts for XXX-s!
3mm pitch, 200 tooth, and 4mm wide... I seriously doubt you will find better belts than Losi's from anyone listed on that other thread.....
aftermarket belts
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-03-2004, 09:55 AM   #8314
John_S's Avatar
but there cheap!!(like the budgie)
John_S is offline   Reply With Quote
Old 01-03-2004, 10:22 AM   #8315
So are the Rolexes that you buy on the street corner in NYC for $10.....
Old 01-03-2004, 10:26 AM   #8316
racer-oZ's Avatar
R/C Tech Charter Subscriber
impactplayr, I wish I had a track to race on a weekly basis that had enough traction to reverse the hubs. We're hoping to find an asphalt surface for the spring.
racer-oZ
racer-oZ is offline   Reply With Quote
Old 01-03-2004, 03:32 PM   #8317
pro3racer's Avatar
nobody knows about the spool construction process?
Old 01-03-2004, 05:12 PM   #8318
Build the diff as regular except don't use the diff balls, diff lube, and place the pads so that the sandpaper side in facing inwards...... tighten her up and go racing...
if you can get 5 extra concave washers placve them in instead of the thrust bearing assembly....
It's not that complicated.....
Old 01-03-2004, 06:37 PM   #8319
pro3racer's Avatar
good, thats how i have been building it, i leave the rings on though, otherwisethe pulley wobbles.
Old 01-03-2004, 08:20 PM   #8320
Still Bill's Avatar
Default Shock travel limiters vs. Droop screws
Can anyone enlighten me about using internal shock travel limiters as opposed to standard droop screws to limit the droop on my XXX-S? What do they use as the limiters? Thanks.
Still Bill is offline   Reply With Quote
Old 01-03-2004, 09:49 PM   #8321
JitsuGuy's Avatar
Send a message via AIM to JitsuGuy
Bill, I have not needed to use any limiters inside my shocks to help with adjusting droop. Just tighten or untighten the shock ends until you get the droop you need. I'm running 2mm in the front and 4mm in the back...
As for what I thought of my new belt with every other tooth missing...BOO HISSSS!!! I felt I lost a lot of the punch I like, so I bought another.
J
JitsuGuy is offline   Reply With Quote
Old 01-03-2004, 09:58 PM   #8322
I tried the belt again today. Worked great in my opinion. I qualified second and the car had a lot more snap off the corner than it used to. The only car to out qualify me was a Yok SD by 5 seconds. I could have easily made up the 5 seconds with some better driving from traffic during qualifying.
James Nguyen is offline   Reply With Quote
Old 01-03-2004, 10:17 PM   #8323
STLNLST's Avatar
Trader Rating: 19 (100%+)
your car was killer today. The main sucked for you but you had the best chance of any one to beat Alex.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-03-2004, 10:30 PM   #8324
I swear to god I could not see at the end of the track with the sun blaring through the doors. Next time I'll have everyone stand in front of the doors so I can see where the corner is. Carpet champs are going to be fun this weekend. I'm going to build another set ot two of shocks for this weekend. Thinking of building a set of maybe 55wt/56 pistons and maybe even a set of 50wt/56 pistons so I can have some shocks to swap out to tune the entry and exit of the turn for this weekends race.
Old 01-03-2004, 10:40 PM   #8325
STLNLST's Avatar
I hit the same corner in my main....LOL I had a glitching problem from hell today. Hopefully I'll get it worked out for next week. I can't wait to get my new car. Good luck next weekend. I might run mod and 19turn if I have the time between racing and calling some of the heats.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
