Old 01-02-2004, 06:01 PM   #8296
Super Steve's Avatar
Send a message via AIM to Super Steve
John S,
Which parts will you be taking off?
Email me as i am interested...
[email protected]
Super Steve is offline   Reply With Quote
Old 01-02-2004, 07:15 PM   #8297
i have also found that layed down shocks will give you more weight transfer, but i have found that the further you lay them down the more the weight transfer becomes side to side transfer(side bite) rather than a forward-back transfer.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 01-02-2004, 08:07 PM   #8298
pro3racer's Avatar
so that would help on a tight track, when your turning more often. I read in the setup sheets, rear toe, is that just from the pivot selction? Still wonderin bout that spool thing.
pro3racer is offline   Reply With Quote
Old 01-02-2004, 08:56 PM   #8299
Originally posted by pro3racer
I read in the setup sheets, rear toe, is that just from the pivot selction? .
if what your asking is how to adjust the rear toe, you cannot adjust rear toe from the rear pivot blocks. you change toe from installing differnet rear hubs 0, 1/2, and 1 degree selections. you can also flip them to opposite sides to take away that amount of toe per side.
[email protected]
Old 01-02-2004, 08:59 PM   #8300
pro3racer's Avatar
gotcha, i gotta start stocking up on hubs now, oh boy, nother trip to the store, knew i forgot something today.
Old 01-02-2004, 11:11 PM   #8301
racer-oZ's Avatar
R/C Tech Charter Subscriber
pro3racer, the 1/2 degree toe in hubs for the rear are most often used on low bite surfaces, if your track is high bite you may not need them. On high bite tracks the extra toe in scrubs off or slows you down on your straight away speed. I run them a lot because we run on a concrete surface that doesn't have a a lot of traction.
racer-oZ
racer-oZ is offline   Reply With Quote
Old 01-02-2004, 11:35 PM   #8302
STLNLST's Avatar
Trader Rating: 21 (100%+)
Originally posted by James Nguyen
Clint - I'll be there. What shock setup were you running on your car?
Todd - Thanks a lot. That was a great explanation. Do you have any input on when to run the steering rack in the forward position or forward flipped instead of in the back position?
56 pistons
50wt oil
blue springs in front
silver in the rear
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 01-03-2004, 06:28 AM   #8303
racer-oZ- when racing on high bite surfaces like carpet you can swap those hubs around (L on right, R on left) to give less toe..... you would do this on Carpet and alot of asphalt tracks around here. This will free-up the rear end.
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 01-03-2004, 06:41 AM   #8304
lem2's Avatar
Default question
on the rear arms of the g+ there are two mounting holes for the rear hub. If I use the outer hole the cvd is almost outside the outdrive, and using the inner hole makes the cvd in perfect position inside the outdrive.
question is:
if I use the outer hole to mount the rear hub, is the cvd prone to popping out?
and
fixing my electronics in the car, are there no balance problems in this car, since all my electronics are small?
lem2 is offline   Reply With Quote
Old 01-03-2004, 06:56 AM   #8305
Default Re: question
question is:
and
Slow down there.... the outer holes are for different hubs, you CANNOT use those hubs in the outer hole....
Old 01-03-2004, 07:16 AM   #8306
lem2's Avatar
Default Re: Re: question
no wonder!!! sorry just fixing up my new ride. No manuals and can't download from the site. Thanks!!
Old 01-03-2004, 07:37 AM   #8307
Regional Moderator
Addict sa RC's Avatar
lem, you can borrow mine. Text me when you're near QC area.
Addict sa RC is offline   Reply With Quote
Old 01-03-2004, 08:42 AM   #8308
highwayman's Avatar
That's one main change of the XXX's to the G+, the inner holes uses the new offset rear hubs for the G+... this is to make the rear rotate more on high bite surfaces with foam tires...
i use the 1 degree standard hubs in the rear
i don't think so... and you can always tweak the car.
highwayman is offline   Reply With Quote
Old 01-03-2004, 08:44 AM   #8309
lem2's Avatar
Default Got it now
the other arm has 2 holes for the rear hub and the other has 1,
i guess it was installed that way to make it look normal.
need new rear arms to make the cvd fit right into the outdrive.
Old 01-03-2004, 08:51 AM   #8310
highwayman's Avatar
the new graphite rear arms of the G+ XXX's really have two holes, what you need are the standard rear hubs if you will mount them on the outer holes or the offset hubs if you will mount them in the inner holes...
the prevous owner of your kit must have used different arms ... get the standard rear hubs...
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
