Losi XXX-S
#8281
hey guys i just got a xxxs from ebay and havent used the car yet, i was just wondering if you had any thaughts for a starting setup for a polished wood floor its got hardly and grip.
O and heres a pic of my car it only cost £130 the way it is there, which i thought wasnt bad considering the speedo thats in it
o and i will be taking most of the red stuff off to lighten it up a bity because i ehard xxxs' were quite heavy as it is
#8283
i race in scotland theres quite a lot of clubs in britian use that surface because the majority of school halls have changed from carpet to wood or linolium which is what i race on but its got the same charactaristics as wood. Iv set up wuite a few cars for this track but was jsut wondering if you guys had an tips fr this specific car.
This kind of track does teach you alot about driving because you have to anticipate the corners more becaus you kind are half sliding while going through them and you need good throttle control, also i think it is more rewarding to drive a clean race on this because it si so small and slidy our hall is only about 20x15 metres.
#8284
Todd, is that theory the opposite for the rear end of the car? The reason I ask is that in testing camber links, it seems the shorter links of front give the car more steering, but shorter links in the rear seem to give the car less rear traction.
Interested to here your thoughts on that.
racer-oZ
racer-oZ
#8285
what does laying your shocks down(or standing them up), do for your handling, front and back?
#8286
Clint - I'll be there. What shock setup were you running on your car?
Todd - Thanks a lot. That was a great explanation. Do you have any input on when to run the steering rack in the forward position or forward flipped instead of in the back position?
#8287
pro3racer, For most cars on carpet, if you lay the shocks down, that end of the car will have more grip because the car can roll more/easier. If you stand the shocks up more the car will tend to roll less at that end and have less grip at that end of the car.
Racer-OZ, I have always thought of camber links like suspension arms: longer arms provide more stability, won't transition as fast, while a shorter one will yeild less grip but transition quicker.
#8288
thanx gary, do you run 28mm foams, if you do, or anybody, do your use any different ball cups, or just dremel them down so the tires don't rub.
#8290
I have noticed that with GP's the balance left/right is a way off.
Has someone tried 5 cells on the left and the 6th at the right side, just near the servo, instead of putting lead?
It's completely creasy?
#8291
RC Driver Gary, I agree with you on the fact that shorter camber links provide quicker transition, but what I've found is the front and rear ends are kind of opposites.
What I mean is this, laying the shocks in on the front has made my XXX-S push, standing them up gives the car more traction and more steering. But on the rear it is just the opposite, laying the shocks down gives more traction or side bite, standing them up gives less side bite, but more forward traction.
Same with camber links, shorter links in the rear have given me less traction, but in the front shorter links give me more traction and steering.
In any event this is a great discussion! I'm interested to hear more input.
racer-oZ
racer-oZ
#8292
what surface? I am talking in regards to carpet. For some reason I have found my asphalt and carpet setups are almost 180 degrees opposite. you have to remember too that you will normally make opposite changes trying to do the same thing to each end of the car. Removing caster up front gives the car more steering. Removing caster in the back aka anti squat should make the car push more. at least this is what I've found
#8293
Im going to get some Fukuyama batteries soon. Ill let you know how they work in my xxxs graphite. They are 1.165-1.169 voltage
#8294
i'm remaking my spool, and my lhs doesn't have the pads, so i'm using sand paper, and the losi site doesn't have instructions on how to make the spool, only the diff, and i don't have the manual. do you just take the balls(pulley, and thrust), and put the pads on.
#8295
Trader Rating: 32 (100%+)
Also camber links are misunderstood a lot of times. They do more to the camber gain and loss of the tire through the arc of the suspension movement and that's where you are getting your stability. When the camber rod is on more of an angle down from the inside out it will have a lot of camber gain....and the shorter you make it the more it will have....so the camber gain of the tire will increase as the suspension compresses....thus decreasing your traction in that tire. If the link is more level inside to outside the camber will remain fairly constant through out the movement. If the rod is at an angle up from the inside to the outside there will be less camber and even positive camber as it compresses so that would yield even more traction to that tire as the suspension moves. Also the shorter you make the tie rod the easier it is to move.....so the car will react faster with a shorter link then a longer one. Hope this helps alittle.
