Losi XXX-S
#8266
Originally posted by STLNLST
James- Whay don't you bring your roomate to the track sometime.....LOL In a couple of hours I can say that I'm undefeated in 04 See you Saturday.
#8268
I make house calls....LOL Is your drive train that bound up that you need to cut the teeth on the belt? Even without my ceramic bearings the drive train is pretty free.
#8269
Too much beer, the room is spinning.
#8271
Okay, all better now...It's about 5 pm here and I was just feeling normal only about an hour ago... LOL
J
J
#8274
Todd - What does mounting the camber link up and between 2 and 3 do on the front shock tower? MF was telling me it would take away steering, but could you tell me what your experiences have been with it? When would you use that hole instead of 2 or 3?
#8275
I tried the brushless today with the same setup as I had been running and the car was decent. It still didn't transition like I wanted to so I went from Purple to green front springs (thanks again kevin) and the car was much better. I threw it on the my integy setup station after the 2nd round and things were a little out of wack, along with a bound up ball cup. Straightened that out and things were ok, but the car was faster in the 2nd round. Before the main, I laid the front shocks down and was realy really happy with how the car was in practice before the main. Tone goes off, the top 3 take it easy, and I got plowed into from behind. 1 broken battery bar, right rear arm, and a rear bumper...sigh. At least I think I found out what changes to make as traction increases. I never tried going to the 2f block, but I may try that early next week.
#8276
Gary, what rear springs are you running?
#8277
#8279
James-On carpet/foam tires we have seen that it makes the car have less steering when the traction comes up. I think the next best location is the #3 hole which will have more steering than the drilled hole and still be somewhat smooth. The #2 hole can be good on a lower bite track but as soon as the traction starts getting high that link can make your car grabby in the center of the turn. On asphalt I have not needed this new drilled hole. I always run the new drilled hole on carpet however I only race big races on carpet. I think on a club race track you will be able to run the #3 hole with no problem.
#8280
James-Also here is another way to think of this. As you raise the inner link(new drilled hole) you will have less camber gain. By having less camber gain you will make that end of your car stiffer. By making it stiffer you are creating less grip to that end of the car. So by lowering the inner link(hole #2 or #3) you are doing just the opposite....you will have more camber gain making that end of the car softer which will give you more grip. Hope that makes sense.
