Losi XXX-S
#8177
Let's see I have...
1 standard diff w/steel outdrives
1 standard diff w/composite outdrives
1 OD/UD diff w/ composite outdrives
1 OD/UD spool w/ composite outdrives
All I need is 1 more outdrive and I will have another spare diff.....LOL
Not to mention the 4 diffs that reside in my 2 G+'s.... I think I may be ready
#8178
wire help
about to change the wire on my esc for the xxxG+, what would be better a longer (+) wire or (-)wire going to the bats, cause obviously one will be longer? Want to do it right for my Losi.
what do u guys usually do?
Thanks!
Lem
Thanks!
Lem
#8179
Al75 FYI. The Off Road belt has more teeth but only because the wheelbase is longer on the XXX-4 compaired to the XXX-S. If you are planning to run the offroad belt on the XXX-S, don't do it!
The extra length will give you problems when you go to use the belt tensioner. You won't be able to tighten the belt enough to keep it from slipping too much and scraping the tunnel, as well as itself, because of the extra length. That is not something you can just "dial out".
#8181
Wire length will only affect overall resistance, nothing else. I heard guys WAY back in the day(91!) saying things about how different length wire will affect "electrical timing" . Won't happen. Electron flow is negative to positive, so length of wire makes no difference.
Matt
Matt
#8182
Thanks Guys!!
Copy!! will do!!
#8183
do u guys snip off every other tooth on the belt?
#8184
I would like to know what you guys mean by (every other tooth) ?
#8185
^^^^^^^^^^^^^ that is how it is when u get the belt
^-^-^-^-^-^-^-^-^ that is where u leave a tooth then cut one then leave one then cut one excetera(sp) it takes a wile to do
#8186
Trader Rating: 32 (100%+)
Kevin...I have run my belt like this for two weekends now and it really helps. It takes about 20 minutes or so to do but its worth it. I just used some lexan sicsors to cut every other tooth off the belt.
#8187
Re: wire help
Thanks!
Lem
Thanks!
Lem
My shorter wire is + so i build my batts with the positive in the rear, just a personal choice, i like the positive nearer to the esc.
#8188
hmmm, what's the advantage? do i need more tension if i do this mod?
#8189
I just finnished taking every other tooth out.does it have to be perfecly flush or can there be a little there still of the tooth?
i guess its supposed to free up the the drive train.
#8190
about the teeth, do you have to cut them flush with the flat part, or do they not have to be exact. Is there an advantage, and how big of one, i'm stocking up on backups this week, and i need to know if i should get a new belt too.
