Old 12-24-2003, 06:52 PM   #8131
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by Kevin K
Are you talking about the kevlar spur gear? If so I have ran it for a while now.....its a spur gear. I mean the only thing that I noticed with it is its harder to strip and it runs a little more straight then the blue ones did.
Ditto on Kevin's comments.
For the new spur, I wouldn't worry about it if you have a good blue spur. If your's wobbles bad, or if you strip it, go for it.
I only bought one after I FUBAR'ed my blue one while playing with "things" and almost killing myself with an x-act knife.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 12-24-2003, 07:02 PM   #8132
MERRY CHRISTMAS TO ALL MY LOSI BROTHERS!!!!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 12-24-2003, 08:34 PM   #8133
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Darn..errr I mean wheew good thing you're ok
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 12-24-2003, 08:36 PM   #8134
RCTech Member #2
TSR6's Avatar
Watch out bub.. I know where your going to be Jan 7-11....
Troy
RCTech Member #2
Old 12-24-2003, 08:37 PM   #8135
Oh boy...i'm scared now troy
USVTA Member #211
Old 12-24-2003, 09:19 PM   #8136
R/C Tech Founder
Or at least, you will be, when he's starting behind you on the grid!
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 12-25-2003, 02:02 AM   #8137
Default Todd Hodge carpet set-up from RCCA??
I have an RCCA rag with a Hodge "baseline" carpet set-up listed in it and it states he has an overall caster of 9 degrees... I'm assuming he would be using the 6 deg. c-hubs, but how does he get 3 degs. of kick-up to arrive at a total of 9 degs. of caster?? Unfortunately their generic set-up sheet leaves no alloinces (sp?) for which carriers/ pin holders that is being used on the car.
Is he using Trinity LRC blocks, or modified Losi pieces??
I am assuming that this is a baseline set-up because it doesn't list a particular track that the set-up is for. I have found that Hodge baseline set-ups are usually fast and very close to what I end up with for my liking so I wanna use this when I finally get to the local carpet track. Any help will be apriciated!!!!
Old 12-25-2003, 08:41 AM   #8138
Super Steve's Avatar
Send a message via AIM to Super Steve
god...
i broke shockshaft, aluminum CVD holes, knuckle, c hub, body posts and a suspension arm...
everything is fixed now... (Steal cvds again, different shocks, new body posts, modified TC3 c hub, spare suspension arm)
Only thing i have now broken is the knuckle. The lower hole has a medium size chunk missing along the threading so a screw will not hold...
I have a 500 lap chrismas oval race... lets hole the broken knuckle does not damage the cvd...
Super Steve is offline   Reply With Quote
Old 12-25-2003, 10:34 AM   #8139
akrcracer's Avatar
Impactplayer, The only way I see him getting 9 degrees of caster. Is Todd might have cut down on Losi inner pivot blocks? I recently read alot of this thread. You guys have some good info here... I found out I have a tweaked chassis. Now I run 1/2 degree hub carrier on right side to give equal toe in. I find my car turns more equally in corners.. I find more caster for me is not enough steering on my carpet track.. So I'm toying with the thought of getting some losi inner blocks and shaving them down a little to add to my tuning options...But how much to shave off them?It will be trail the error.. Merry Christmas to all.
akrcracer is offline   Reply With Quote
Old 12-25-2003, 02:38 PM   #8140
TLRacing
Todd Hodge's Avatar
IMPACTPLYR-That must be a typo in RCCA...I run -2 antidive with 6 degree blocks. I use the stock TL low roll center mounts with the 0F block. I have never ran 9 degrees.
EnergyRacing-I just build my shocks the way it is described in the manual. The do eventually get some air in them and then I just rebuild them. I also make sure there is no pressure when the shock is fully compressed.
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 12-25-2003, 04:42 PM   #8141
Sweet!! who better to answer my question about a Todd Hodge set-up!!! Thanks Todd... also they may have either wis calculated or had a typo as you stated.... Reevaluating the set-up I do see you are using the 0F block....... however they have you running prosquat in the rear with the 2R blocks??? another typo???
Also how do you measure droop when you run foams?? I am assuming they measurements are actually uptravel and not from the droop guage???
Thanks agian!!! I won't bother you with any more questions right now!!! But I could probably ask enough for you to write a book!!!
Old 12-26-2003, 07:55 AM   #8142
TLRacing
Todd Hodge's Avatar
IMPACTPLAYR-on that setup I did run 2 degrees of prosquat. I ran the 2R block in the HRC holes on the diff cover and then I had my rear pivots shimmed up .020. I use my handy TL droop gauge to measure the droop but I also keep an eye on actual chassis uptravel when i do change the droop.
Todd Hodge
Old 12-26-2003, 09:37 AM   #8143
spenzalii's Avatar
Send a message via AIM to spenzalii
Huzzah! It's always good when factory racers go online and talk with the masses. Welcome Todd.
Question for you guys. 19T seems to be growing in my area, and I'm going to try it out. On a medium sized, technical trak (haven't seen it yet, but that's what I heard) using the stock 90t, 48p gear for the original XXX-S (no I haven't upgraded yet, but I will soon enough!), what should I look for pinion wise with a Cham2 based motor? There's no baseline guide in the manual for anything close to a 19
Oh, and the Mini-T ROCKS! Any plans on a Mini XXX-S? Todd? I know you can go down to R&D...
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 12-26-2003, 10:33 AM   #8144
CGR
CGR's Avatar
Gear a C2 the same as a Monster and adjust as needed for your track.
CGR is offline   Reply With Quote
Old 12-26-2003, 10:34 AM   #8145
Thanks agian Todd, a few more questions and I will stop bothering you....
Where do you true your foams down to to start with on carpet?
I see the set-up was for the IS300, I personally have tried the IS and all but hated it... the thing pushed like a pig... however this was on Asphalt.... I tried it because on the Losi site it states that the Lexus IS300 is designed for "more agressive handling" are the effects I felt the same on carpet? or do you mount the body forward on the chassis to gain extra steering? the pictures look like the body is mounted forward....
Otherwise what other bodies do you recommend for carpet running a stock motor?
Thanks agian in advance!!!
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
